HP 280 G5 Microtower Business PC Specifications
Product image
Operating systems
Specification
Pre-installed (Windows)
Windows 10 Pro 64
Not all features are available in all editions or versions of Windows. Systems might require upgraded and/or separately purchased hardware, drivers, software, or BIOS update to take full advantage of Windows functionality. Windows 10 automatic updates are always enabled. ISP fees might apply and additional requirements might apply over time for updates.
Pre-installed (other)
FreeDOS 1.2
In accordance with Microsoft support policy, this product does not support Windows 8 or Windows 7. HP does not support the Windows 8 or Windows 7 operating system on products configured with Intel and AMD 7th generation or later processors, or provide any Windows 8 or Windows 7 drivers.
Processors
Specification
Intel Core i7-9700 Processor
3.0 GHz, up to 4.8 GHz with Intel Turbo Boost technology
12 MB cache, 8 cores
Intel UHD Graphics 630
Supports Intel vPro technology
Intel Core i5-9600 Processor
3.1 GHz, up to 4.9 GHz with Intel Turbo Boost technology
9 MB cache, 6 cores
Intel Core i5-9500 Processor
3.0 GHz, up to 4.1 GHz with Intel Turbo Boost technology
9 MB cache, 6 cores
Intel Core i5-9500F Processor
3.0 GHz, up to 4.4 GHz with Intel Turbo Boost technology
9 MB cache, 6 cores
Intel Core i5-9400 Processor
2.9 GHz, up to 4.1 GHz with Intel Turbo Boost technology
9 MB cache, 6 cores
Intel Core i5-9400F Processor
9 MB cache, 6 cores
Intel Core i3-9300 Processor
3.7 GHz, up to 4.3 GHz with Intel Turbo Boost technology
8 MB cache, 4 cores
Intel Core i3-9100 Processor
3.6 GHz, up to 4.2 GHz with Intel Turbo Boost technology
6 MB cache, 4 cores
Intel Core i7-8700 Processor
3.2 GHz, up to 4.6 GHz with Intel Turbo Boost technology
12 MB cache, 6 cores
Intel Core i5-8500 Processor
9 MB cache, 6 cores
Intel Core i5-8400 Processor
2.8 GHz, up to 4.0 GHz with Intel Turbo Boost technology
9 MB cache, 6 cores
Intel Core i3-8100 Processor
3.6 GHz base frequency
6 MB cache, 4 cores
Intel Pentium Gold G5420 Processor
3.8 GHz base frequency
4 MB cache, 2 cores
Intel UHD Graphics 610
Intel Pentium Gold G5600 Processor
3.9 GHz base frequency
4 MB cache, 2 cores
Intel Pentium Gold G5620 Processor
4.0 GHz base frequency
4 MB cache, 2 cores
Intel Pentium Gold G5400 Processor
3.7 GHz base frequency
4 MB cache, 2 cores
Intel Pentium Gold G5500 Processor
4 MB cache, 2 cores
Intel Celeron G4930 Processor
3.2 GHz base frequency
2 MB cache, 2 cores
Intel Celeron G4900 Processor
3.1 GHz base frequency
2 MB cache, 2 cores
Intel B365 Chipset
Multicore is designed to improve performance of certain software products. Not all customers or software applications necessarily benefit from use of this technology. 64-bit computing system required. Performance and clock frequency vary depending on application workload and hardware and software configurations. Intel numbering is not a measurement of higher performance.
Some functionality of vPro technology, such as Intel Active management technology and Intel Virtualization technology, requires additional 3rd party software in order to run. Future virtual appliances applications dependent on third-party software and compatibility to be determined.
Memory
Specification
DDR4-2666
Maximum: 32 GB
Number of slots: (2) DIMM
Up to 2666 MT/s
Configurations
4 GB DDR4-2666 UDIMM NECC (1 x 4 GB)
8 GB DDR4-2666 UDIMM NECC (1 x 8 GB)
8 GB DDR4-2666 UDIMM NECC (2 x 4 GB)
16 GB DDR4-2666 UDIMM NECC (1 x 16 GB)
16 GB DDR4-2666 UDIMM NECC (2 x 8 GB)
Maximum memory capacities assume Windows 64-bit operating systems. With Windows 32-bit operating systems, memory above 3 GB might not all be available due to system resource requirements.
Graphics
Specification
Integrated graphics
Intel UHD Graphics 630 (integrated on 9th and 8th gen Core i9/i7/i5 processors)
Intel UHD Graphics 610 (integrated on Pentium Gold, Celeron processors)
Discrete (optional) graphics
AMD Radeon R7 430 2 GB GFX
AMD Radeon RX 550X 4GB GFX
AMD Radeon 520 1 GB GFX
NVIDIA GeForce GT 730 2 GB GFX
Storage
Specification
SATA drives
500 GB, 7.2 K rpm, 8.89 cm (3.5 in)
1 TB, 7.2 K rpm, 8.89 cm (3.5 in)
2 TB, 7.2 K rpm, 8.89 cm (3.5 in)
Solid State Drives (SSD)
256 GB, SATA 3 (6.0 Gb/s), 6.35 cm (2.5 in), TLC SSD
512 GB, SATA 3 (6.0 Gb/s), 6.35 cm (2.5 in), TLC SSD
128 GB M.2 2280 PCIe NVMe TLC SSD
256 GB M.2 2280 PCIe NVMe TLC SSD
512 GB M.2 2280 PCIe NVMe TLC SSD
256 GB M.2 2280 PCIe NVMe SSD
512 GB M.2 2280 PCIe NVMe SSD
Optical disk drives
9.5 mm Slim DVD-ROM
9.5 mm Slim DVD Writer
Media card reader
Supports SD, SDHC, and SDXC
For hard drives and solid state drives, GB = 1 billion bytes and TB = 1 trillion bytes. Actual formatted capacity is less. Up to 30 GB of system disk is reserved for the system recovery software.
Keyboards/pointing devices
Specification
Keyboards
USB Business Slim Wired Keyboard
HP USB Wired Keyboard Business Slim
USB Antimicrobial Wired Keyboard (China)
Business Slim PS/2 Wired Keyboard
No Keyboard option
Mice
Antimicrobial USB Mouse (China)
HP Optical USB Mouse
Universal Wired USB Mouse
USB Hardened Mouse (India)
HP PS/2 Mouse (for machine configured with PS/2 port)
No Mouse option
Ports/slots/bays
Specification
Ports
USB ports
(4) USB 2.0 (rear)
(4) USB 3.1 Gen 2 (front)
Video ports
Port is covered up when configured with processor which is without internal graphics.
(1) HDMI port
(1) VGA port
Audio ports
(1) Headphone/microphone jack (front)
(1) Audio input (rear)
(1) Audio output (rear)
Network/communication ports
(1) RJ-45 Ethernet (rear)
Power
(1) Power port (rear)
Optional rear ports
(2) PS/2 port (optional)
(1) Parallel port (Optional via PCIe x1 slot)
(1) 4x Serial port (Optional via PCIe x1 slot)
(1) Internal speaker (optional)
(1) M.2 PCIe (for WLAN)
(2) M.2 PCIe 2280/2230 (for storage)
(1) Full-height PCI
(1) PCI Express v3.0 x1
(1) PCI Express v3.0 x16
Bays
(1) SD card reader (optional)
(1) 9.5 mm external slimline ODD bay (optional)
(1) 8.89 cm (3.5 in) internal HDD or 6.35 cm (2.5 in) internal SSD bay
(1) 8.89 cm (3.5 in) internal HDD (share bay with caddy)
Audio/multimedia
Feature
Audio (integrated)
Realtek ALC3601
2 W per channel class D stereo amplifier for the internal speakers only
(1) Front headset connector supports a CTIA style headset
(1) Rear Line-out
(1) Rear Line-in
Networking/communications
Specification
Ethernet (RJ-45) integrated
Integrated 10/100/1000M GbE LAN
Wireless LAN
Realtek 802.11ac (1x1) Wi-Fi and Bluetooth 4.2 Combo
Wireless access point and Internet service required and not included. Availability of public wireless access points limited. The specifications for the 802.11ac WLAN are draft specifications and are not final. If the final specifications differ from the draft specifications, it might affect the ability of the device to communicate with other 802.11ac WLAN devices.
Software/security
Specification
HP Utilities and Support
HP Documentation
HP JumpStart
HP Audio Switch (switch between speaker and microphone sources with intuitive controls and a consistent app experience)
HP Support Assistant
HP Setup Integrated OOBE
HP System Event Utility
Security
McAfee LiveSafe (available for LA region only)
Free 12-month subscription of McAfee LiveSafe service included. Internet access required and not included. Subscription required after expiration.
Productivity
Buy Office (sold separately)
Dropbox
New Dropbox users are eligible to get 25 GB of Dropbox space free for 12 months from date of registration. Internet service required and not included. For more information, go to Dropbox website.
Multimedia and apps
ODD playback
sMedio True DVD for HP
Movies
Netflix (internet access required)
App Stores and content purchasing
Amazon (internet access required)
Power supply
Specification
Power supply
180 W
ENERGY STAR EPA 90 (Gold) Full range 115 V/230 V
310 W
Power supply varies by country/region.
Physical specifications
Specification
Chassis dimensions (W x D x H)
15.54 x 30.30 x 33.73 cm (6.12 x 11.93 x 13.28 in)
System weight
4.7 kg (10.36 lb)
Weight varies by configuration.
Environmental
Specification
ENERGY STAR
Certified models available
EPEAT
EPEAT Gold (registered where applicable/supported)
Registration status varies by country/region.
