Product Specifications for the HP Smart Tank Plus 651 Wireless All-in-One (7XV38A)
Product naming
Model name
7XV38A
What's included and accessories
What's in the box
HP Smart Tank Plus 651 Wireless All-in-One; HP 32XL 135-ml Black Original Ink Bottle; HP 31 70-ml Cyan Original Ink Bottle; HP 31 70-ml Magenta Original Ink Bottle; HP 31 70-ml Yellow Original Ink Bottle; Ink caution flyer; Repacking flyer; Setup guide; Reference guide; Regulatory flyer; PT flyer; RoH-EAC Regulatory flyer; Power cord [For more information about fill and yield, see http://www.hp.com/go/learnaboutsupplies]
Connectivity
Ports
Hi-Speed USB 2.0, Dual Band Wi-Fi with Bluetooth LE
Wireless capability
Yes, built-in dual band Wi-Fi 802.11b/g/n, Wireless direct, BLE
Copy
Copier settings
Number of Copies, Resize, Quality, Lighter/Darker, Papersize, Papertype, ID Copy, Collate, Enhancement
Color copy capability
Yes
Maximum number of copies
Up to 99 copies
Copy reduce / enlarge settings
25 to 400%
Copy speed, black (draft, A4)
Up to 22 cpm
Copy speed, black (draft, Letter)
Up to 22 cpm
Copy resolution
Up to 600 dpi
Environmental
Acoustic power emissions (active, printing)
6.4 B(A)
Acoustic pressure emissions
50 dB
Recommended operating humidity range
20 to 80% RH
Non-Operating Humidity Range
5 to 90% RH (non-condensing)
Recommended operating temperature range (Celsius)
15 to 30°C
Recommended operating temperature range (Fahrenheit)
59 to 86°F
Storage temperature range (Celsius)
-40 to 60°C
Storage temperature range (Fahrenheit)
-40 to 140°F
Environmental specifications
No
Fax
Fax available
Yes, color
Fax features
Color Fax; Auto Reduction; Auto Redial; Speed Dial; Group Speed Dial; Junk Barrier; Forwarding (Black Only); Scan and Fax; PC Fax Send and Fax to PC
Fax Resolution Black (best)
Up to 300 x 300 dpi
Telephone handset supported
No
Fax telephone mode supported
Yes
Modem
Internal. Data transfer rate up to 33.6kbps
Fax transmission speed (letter)
4 sec per page
Memory
Memory
Integrated memory
Maximum Memory
256 MB
Mobile printing capability
Mobile printing services
HP Smart app; Apple AirPrint™; HP ePrint; Mopria™-certified
Networking
Network protocols, supported
9100, SNMP, SLP, IPP, WS-Print, Wireless, LPR
Paper handling
Input capacity
Up to 100 sheets
Standard input capacity (cards)
Up to 30 cards
Standard input capacity (envelopes)
Up to 10
Output capacity
Up to 30 sheets
Media sizes supported (metric)
A4; B5; A6; DL envelope, legal
Media sizes supported (U.S. standard)
Letter; legal; 4 x 6 in; 5 x 7 in; 8 x 10 in; No. 10 envelopes
Media sizes, custom (metric)
76.2 x 127 to 215 x 355 mm
Media sizes, custom (U.S. standard)
3 x 5 in to 8.5 x 14 in
Media types
Plain paper, Matte Brochure Papers, Glossy Brochure Papers, Photo papers, Envelopes, Other specialty inkjet papers
Media weight supported (metric)
75 g/m²
Media weight supported (U.S. standard)
Plain paper: 16 to 24 lb; Envelopes: 20 to 24 lb; Cards: up to 110 lb; Photo paper: up to 80 lb
Borderless printing
Yes (up to 8.5 x 11 in, 210 x 297 mm)
Paper handling - ADF
Automatic document feeder capacity
Standard, 35 sheets
Paper handling - duplexer
Media sizes, duplex (U.S. standard)
Letter; Executive
Physical dimensions
Maximum dimensions (W x D x H, metric)
449 x 605.65 x 258.7 mm
Maximum dimensions (W x D x H, U.S. standard)
17.7 x 23.8 x 10.18 in
Weight (metric)
6.19 kg
Weight (U.S. standard)
13.64 lb
Power
Energy savings feature technology
HP Auto-Off Technology
Internal
Power supply
Input voltage 100 to 240 VAC (+/- 10%), 50/60 Hz (+/- 3 Hz). High voltage: Input voltage 200 to 240 VAC (+/- 10%), 50/60 Hz (+/- 3Hz)
Power consumption
0.11 watts (manual-off), 3.82 watts (ready), 0.71 watt (sleep)
Print cartridges
Number of print cartridges
4 (1 each black bottle, set of 3 color bottles)
Replacement cartridges
HP 32XL 135-ml Black Original Ink Bottle (1VV24AN); HP 31 70-ml Cyan Original Ink Bottle (1VU26AN); HP 31 70-ml Magenta Original Ink Bottle (1VU27AN); HP 31 70-ml Yellow Original Ink Bottle (1VU28AN)
Printing specifications
Print technology
HP Thermal Inkjet
Duplex printing
Manual (driver support provided)
Print speed (color, draft, Letter)
Up to 16 ppm
Print speed black (ISO)
Up to 11 ppm
Print speed color (ISO)
Up to 5 ppm
Print resolution (best)
Up to 4800 x 1200 optimized dpi color when printing from a computer and 1200 input dpi
Maximum print area (metric)
216 x 355 mm
Monthly duty cycle
Up to 1000 pages
Print languages
HP PCL 3 GUI
Regulatory specifications
Regulatory model number
SNPRC-1804-02
Safety
IEC 60950-1 & IEC 62368-1 compliant; Safety UL listed; EU LVD and EN 60950 & EN 62368 compliant; UL GS approved
Electromagnetic compatibility
CISPR 32:2015/EN 55032:2015 Class B; CISPR24:2010/EN 55024:2010; EN 61000-3-2:2014; EN 61000-3-3:2013; FCC CFR 47 Part 15B; ICES-003,2016 Issue 6; EN 301 489-1 V2.1.1:2017; EN 301 489-17 V3.1.1:2017; FCC Rules and Regulations 47 CFR Part 68/TIA-968-B; ES 203 021-2/ES 203 021-3
Telecom compliance (fax capability)
EN 300 328 V2.1.1:2016; EN 301 893 V2.1.0:2021
Scan
Scan technology
Contact Image Sensor (CIS)
Scan speed (normal)
Up to 3 ppm (200 ppi, color); Up to 5 ppm (200 ppi, mono)
Scan resolution, hardware
Up to 1200 x 1200 dpi
Levels of grayscale
256
Bit depth
24-bit
Scanning options (ADF)
Single-sided
Maximum flatbed scan size (metric)
216 x 297 mm
Maximum flatbed scan size (U.S. standard)
8.5 x 11.69 in
Maximum ADF scan size (metric)
216 x 356 mm
Maximum ADF scan size (U.S. standard)
8.5 x 14 in
Twain version
Version 2.1
Security
Security management
No
System requirements
Minimum system requirements for Windows
Windows 10, 8, 7: 32-bit or 64-bit, 2 GB available hard disk space, Internet connection, USB port, Internet Explorer.
Recommended system requirements for Windows
Minimum System Requirements for Macintosh
OS X v10.11 El Capitan and above, Internet Access
Recommended Macintosh system requirements
Operating system (supported note)
Windows 10, 8, 7; OS X v10.11 El Capitan, macOS Sierra v10.12 (previously OS X), macOS High Sierra v10.13, macOS Mojave v10.14
One year of 24/7 world-class technical support services through http://www.hp.com/support; One-year or 30,000 pages limited hardware warranty, whichever is earlier from the date of purchase; user replaceable parts have separate warranty periods
