    Microsoft Support for Windows 7 ended on Jan 14, 2020
    - HP recommends that you begin the process of upgrading to Windows 10 if your computer has been tested by HP. For more information, click here.
    - If your computer is not compatible for upgrade to Windows 10, we can help to find the perfect computer for you. Check our Weekly deals!
HP Pavilion Gaming - TG01-0013ur Product Specifications
Product Number
8KJ28EA
Product Name
Motherboard
Rother
Motherboard Specifications Link
Memory
16 GB DDR4-2666 SDRAM (2 x 8 GB)
Memory & Storage
16 GB memory; 1 TB SSD storage
Internal Storage
1 TB PCIe® NVMe™ M.2 SSD
Processor Type
Intel Core i7
Processor
Intel® Core™ i7-9700F (3 GHz base frequency, up to 4.7 GHz with Intel® Turbo Boost Technology, 12 MB cache, 8 cores)
Processor Family
9th Generation Intel® Core™ i7 processor
Processor Speed
3 GHz
Graphics
Discrete
Graphics Card
NVIDIA® GeForce® GTX 1660 Ti Graphics (6 GB GDDR6 dedicated)
Ports
1 USB 3.1 Gen 1 Type-C™; 4 USB 3.1 Gen 1 Type-A; 1 headphone/microphone combo
Expansion Slots
1 PCIe x4; 1 PCIe x16; 2 PCIe x1; 2 M.2
Network Interface
Wireless
Realtek 802.11b/g/n/a/ac (1x1) and Bluetooth® 4.2 combo
Optical Drive
Optical drive not included
Memory Card Device
HP 3-in-1 Media Card Reader
Dimensions
15.54 x 30.7 x 33.74 cm
5.96 kg
Power Supply Type
400 W Platinum efficiency power supply
HP Apps
HP Audio Switch; HP Support Assistant
Software Included
Operating System
