    Microsoft Support for Windows 7 ended on Jan 14, 2020
    - HP recommends that you begin the process of upgrading to Windows 10 if your computer has been tested by HP. For more information, click here.
    - If your computer is not compatible for upgrade to Windows 10, we can help to find the perfect computer for you. Check our Weekly deals!
HP Slim Desktop - S01-pF0320nd Product Specifications
Product Number
8AP85EA
Product Name
Motherboard
Milton
Motherboard Specifications Link
Memory
Memory & Storage
8 GB memory; 512 GB SSD storage
Internal Storage
512 GB PCIe® NVMe™ M.2 SSD
Processor Type
Intel Core i3
Processor
Intel® Core™ i3-9100 (3.6 GHz base frequency, up to 4.2 GHz with Intel® Turbo Boost Technology, 6 MB cache, 4 cores)
Processor Family
9th Generation Intel® Core™ i3 processor
Processor Speed
3.6 GHz
Graphics
Integrated
Graphics Card
Intel® UHD Graphics 630
Ports
4 USB 3.1 Gen 1 Type-A; 1 headphone/microphone combo
Expansion Slots
2 M.2
Network Interface
Wireless
Realtek 802.11b/g/n/a/ac (1x1) and Bluetooth® 4.2 combo
Optical Drive
Optical drive not included
Memory Card Device
HP 3-in-1 Media Card Reader
Dimensions
9.5 x 30.3 x 27 cm
3.02 kg
Power Supply Type
180 W Gold efficiency power supply
HP Apps
HP Audio Switch; HP Support Assistant
Software Included
Operating System
