    Coronavirus (COVID-19) Impact
    We are experiencing longer than expected wait times to reach an agent. Please use the resources here on our HP Support website to answer your questions and troubleshoot any issues you may be experiencing.  Try our Virtual Agent and Diagnostic Tools for faster service.
    Microsoft Support for Windows 7 ended on Jan 14, 2020
    - HP recommends that you begin the process of upgrading to Windows 10 if your computer has been tested by HP. For more information, click here.
    - If your computer is not compatible for upgrade to Windows 10, we can help to find the perfect computer for you. Check our Weekly deals!
HP Notebook - 15-db0145ca Product Specifications
8RJ34UA
AMD A6-9225 Dual-Core (2.6 GHz base frequency, up to 3 GHz burst frequency, 1 MB cache)
AMD Integrated SoC
8 GB DDR4-1866 SDRAM (1 x 8 GB)
Video graphics
AMD Radeon™ R4 Graphics
256 GB M.2 SSD
Optical drive
DVD-Writer
15.6" diagonal HD SVA BrightView micro-edge WLED-backlit touch screen (1366 x 768)
Realtek 802.11b/g/n/a/ac (2x2) and Bluetooth® 4.2 combo
2 USB 3.1 Gen 1 (Data transfer only); 1 USB 2.0; 1 HDMI 1.4b; 1 RJ-45; 1 headphone/microphone combo
37.6 x 24.6 x 2.25 cm
1.77 kg
45 W Smart AC power adapter
3-cell, 41 Wh Li-ion
Dual speakers
Pre-installed software
Netflix (30-day free trial offer)
