    Windows 11 Upgrade Guide
     Connect with HP support faster, manage all of your devices in one place, view warranty information and more. Sign up for an HP account
HP Elite Dragonfly Notebook PC Specifications
Product image
Operating systems
Specification
Preinstalled
Windows 10 Pro 64 (National Academic only)
Some devices for academic use automatically update to Windows 10 Pro Education with the Windows 10 Anniversary Update. Features vary.
Windows 10 Pro 64
Windows 10 Pro (Windows 10 Enterprise available with a Volume Licensing Agreement)
Not all features are available in all editions or versions of Windows. Systems might require upgraded and/or separately purchased hardware, drivers, software or BIOS update to take full advantage of Windows functionality. Windows 10 automatic updates are always enabled. ISP fees might apply and additional requirements might apply over time for updates.
FreeDOS 1.2
In accordance with Microsoft support policy, this product does not support Windows 8 or Windows 7. HP does not support the Windows 8 or Windows 7 operating system on products configured with Intel 7th generation or later processors, or provide any Windows 8 or Windows 7 drivers.
Processors
Feature
Intel Core i3-8145U
2.1 GHz base frequency
Up to 3.9 GHz with Intel Turbo Boost Technology
4 MB L3 cache, 2 cores
Intel UHD Graphics 620
Intel Core i5-8265U
1.6 GHz base frequency
6 MB L3 cache, 4 cores
Intel Core i5-8365U vPro
Up to 4.1 GHz with Intel Turbo Boost Technology
Supports Intel vPro Technology
Intel Core i7-8565U
1.8 GHz base frequency
Up to 4.6 GHz with Intel Turbo Boost Technology
8 MB L3 cache, 4 cores
Intel Core i7-8665U vPro
1.9 GHz base frequency
Up to 4.8 GHz with Intel Turbo Boost Technology
Integrated with processor
Multicore is designed to improve performance of certain software products. Not all customers or software applications necessarily benefit from use of this technology. Performance and clock frequency vary depending on application workload and hardware and software configurations. Intel numbering is not a measurement of higher performance.
For full Intel vPro functionality, Windows, a vPro-supported processor, vPro-enabled chipset, vPro-enabled WLAN card and discrete TPM 2.0 are required. Some functionality of the vPro technology - such as Intel Active management technology and Intel Virtualization technology require additional 3rd party software in order to run.
Graphics
Feature
Integrated
High-definition (HD) content is required to view high definition images.
Supports
HD decode
DirectX 12
HDMI 1.4b
Feature
Displays (optional)
33.8 cm (13.3 in) diagonal FHD IPS eDP with PSR BrightView WLED-backlit Ultraslim touchscreen, direct bonded with Corning Gorilla Glass 5, 400 nits, 72% NTSC (1920 x 1080)
33.8 cm (13.3 in) diagonal FHD IPS eDP with PSR BrightView WLED-backlit Ultraslim touchscreen, direct bonded with Corning Gorilla Glass 5 and HP Sure View Integrated Privacy Screen, 1000 nits, 72% NTSC (1920 x 1080)
33.8 cm (13.3 in) diagonal 4K IPS eDP with PSR BrightView WLED-backlit Ultraslim touchscreen, direct bonded with Corning Gorilla Glass 5, 550 nits, 69% NTSC (3840 x 2160)
HP Sure View Integrated Privacy screen is optional and must be configured at purchase.
Resolutions are dependent upon monitor capability, and resolution and color depth settings.
Features
Supports dual display through the dock
Storage
Feature
M.2 Solid State Drive (SSD)
128 GB SATA-3 TLC
256 GB PCIe NVMe Value
512 GB PCIe NVMe Value
256 GB PCIe Gen 3 x4 NVMe TLC
512 GB PCIe Gen 3 x4 NVMe TLC
1 TB PCIe Gen 3 x4 NVMe TLC
2 TB PCIe Gen 3 x4 NVMe TLC
256 GB SATA-3 TLC SED OPAL 2
512 GB SATA-3 TLC SED OPAL 2
512 GB SATA-3 TLC FIPS
256 GB M2 PCIe NVMe QLC with 16 GB Intel Optane H10 Memory
512 GB M2 PCIe NVMe QLC with 32 GB Intel Optane H10 Memory
Intel Optane memory system acceleration does not replace or increase the DRAM in your system.
For storage drives, GB = 1 billion bytes and TB = 1 trillion bytes. Actual formatted capacity is less. Up to 30 GB (for Windows 10) is reserved for system recovery software.
Memory
Feature
Standard
16 GB LPDDR3-2133 SDRAM (transfer rates up to 2133 MT/s)
Soldered down, on-board memory (customer non-accessible)
Dual channel supported
Configurations
8 GB LPDDR3-2133 SDRAM
Maximum
16 GB
Due to the non-industry standard nature of some third-party memory modules, only HP branded memory is recommended to ensure compatibility. If memory speeds are mixed, the system performs at the lower memory speed.
Audio/multimedia
Feature
Audio
Bang & Olufsen (B&O)
(4) Premium stereo speakers (1609 x 2 pcs, 1338 x 2 pcs)
(3) Integrated multi-array microphones
(4) Discrete amplifiers
Camera
Hybrid HD RGB 720p and IR Camera (with privacy shutter)
IR camera (internet access required)
Keyboard/pointing devices/pen/function keys/sensors
Feature
Keyboard
HP Premium Collaboration Keyboard
Full-sized, spill-resistant
DuraKeys
Backlight enabled
Pointing device
Clickpad with glass cover
Multi-touch gestures enabled by default
Touchscreen pen
HP Rechargeable Active Pen G3
Sold separately or as an optional feature.
Function keys
F1 – Display switching
F2 – Sure View (blank if not supported)
F3 – Brightness down
F4 - Brightness up
F5 - Audio mute/unmute
F6 - Volume down
F7 - Volume up
F8 - Microphone mute/unmute
F9 - Backlight toggle
F10 - Num Lock
F11 - Wireless
F12 - Calendar
Other keys
Share/Present
Pick Up/Accept/Answer/Hold
Hang Up/Decline/Reject
Delete
FN key lock
Hidden function keys
Fn+R - Break
Fn+S - Sys Rq
Fn+C - Scroll Lock
Fn+E - Insert
Fn+W - Pause
Sensors
Accelerometer
Magnetometer
Gyrometer
Ambient light sensor (ALS)
Hall sensor
Ports/slots
Feature
Ports and connectors
(2) USB 3.1 Type-C with Thunderbolt (supports Power Delivery 3.0)
(1) USB 3.1 Gen 1 (charging)
(1) HDMI 1.4 (cable sold separately)
(1) Headphone/microphone combo jack
Slots
(1) External Nano SIM slot for WWAN (not user accessible without WWAN configuration)
Networking/communication
Feature
Wireless LAN (optional)
Intel AX200 (2x2) and Bluetooth 5 Wi-Fi 6 Combo (vPro)
Intel AX200 (2x2) and Bluetooth 5 Wi-Fi 6 Combo (non-vPro)
Wireless access point and internet service required and not included. Availability of public wireless access points limited. Wi-Fi 6 is backwards compatible with prior 802.11 specs. The specifications for the 802.11ax WLAN are draft specifications and are not final. If the final specifications differ from the draft specifications, it might affect the ability of the notebook to communicate with other 802.11ax WLAN devices.
Wireless WAN
Intel XMM 7360 LTE-Advanced Cat 9
Intel XMM 7560 LTE-Advanced Pro Cat 16
WWAN is an optional feature and requires separately purchased service contract. Check with service provider for coverage and availability in your area. Connection speeds might vary due to location, environment, network conditions, and other factors. 4G LTE not available on all products, in all regions.
Communications
Compatible with Miracast-certified devices
Ethernet
No direct Ethernet Support (only via accessories)
Software/security
Feature
BIOS
HP BIOSphere Gen5
HP DriveLock and Automatic DriveLock
BIOS Update via Network
HP Sure Start Gen5
Pre-boot Authentication
Secure Erase (methods outlined in the National Institute of Standards and Technology Special Publication 800-88)
Absolute Persistence Module1
Communication/connectivity
Native Miracast support
HP Connection Optimizer
HP Value Add Software
HP Hotkey support
HP Recovery Manager—CMIT
HP Jumpstart
HP Support Assistant (requires Windows and internet access)
HP Noise Cancellation software
HP Sure Click (available on select HP platforms and supports Microsoft internet Explorer, Google Chrome, and Chromium.)
Microsoft products
Buy Office (sold separately)
Manageability features
HP Driver Packs (available for download)
HP System Software Manager (SSM) (available for download)
HP BIOS Config Utility (BCU) (subscription required)
HP Client Catalog (available for download)
HP Manageability Integration Kit Gen3 (available for download)
HP Fingerprint Sensor (sold separately or as an optional feature)
HP Cloud Recovery
Available for HP Elite and Pro desktops and laptops PCs with Intel or AMD processors and requires an open, wired network connection.
Client security software
Microsoft Defender
Opt in and internet connection required for updates.
Trusted Platform Module (TPM) 2.0
Embedded security chip shipped with Windows 10
Common Criteria EAL4+ Certified
HP Client Security Manager Gen5
Requires Windows and Intel or AMD 7th or 8th generation processors.
HP Security Manager (HP Credential Manager, HP Password Manager, HP Spare Key)
HP Power On Authentication
HP Sure Click
HP Sure Run Gen2
HP Sure Recover Gen2
HP Sure Sense (requires Windows 10)
Hardware security
RAID configurations (optional and requires a second hard drive)
Serial, USB enable/disable (via BIOS)
Power-on password (via BIOS)
Setup password (via BIOS)
Support for chassis padlocks and cable lock devices
1Absolute agent is activated when customers activate a purchased subscription. Subscriptions can be purchased for terms ranging multiple years. Service is limited, check with Absolute for availability outside the U.S. The Absolute Recovery Guarantee is a limited warranty. Certain conditions apply. Data Delete is an optional service provided by Absolute Software. If utilized, the Recovery Guarantee is null and void. In order to use the Data Delete service, customers must first sign a Pre-Authorization Agreement and either obtain a PIN or purchase one or more RSA SecurID tokens from Absolute Software.
HP Cloud Recovery download tool (Cloud Recovery Client) is available under Software and Drivers section on the support page.
Power
Feature
Power supply
HP Smart 65 W USB Type-C adapter
Availability might vary by country/region.
Primary battery
HP Long Life, 2-cell, 38 Wh Li-ion polymer
HP Long Life, 4-cell, 56.2 Wh Li-ion polymer
Supports battery fast charging (up to 50% in 30 minutes)
Recharges the battery up to 50% within 30 minutes when the system is off or in standby mode. Power adapter with a minimum capacity of 65 Watts is required. After charging has reached 50% capacity, charging returns to normal. Charging time may vary +/-10% due to system tolerance.
Battery is internal and not replaceable by customer. Serviceable by warranty.
Power cord
1.0 m (3.28 ft), Duckhead power cord (C5NS), sticker, premium black
Premium 1.0 m (3.28 ft), power cord C5 Sticker
Physical specifications
Feature
Dimensions (W X D X H)
30.43 x 19.76 x 1.60 cm (11.98 x 7.78 x 0.63 in)
Starts at 0.99 kg (2.18 lb) (not including the power adapter)
Weight varies by configuration and components.
