8FA83EA
HP Pavilion x360 - 14-dh1008nl
Intel® Core™ i5-10210U (1.6 GHz base frequency, up to 4.2 GHz base with Intel® Turbo Boost Technology, 6 MB cache, 4 cores)
Intel® Integrated SoC
Video graphics
Intel® UHD Graphics
256 GB PCIe® NVMe™ M.2 SSD
Optical drive
Optical drive not included
35.6 cm (14") diagonal FHD IPS micro-edge WLED-backlit multitouch-enabled edge-to-edge glass (1920 x 1080)
1 USB 3.1 Gen 1 Type-C™ (Data Transfer Only, 5 Gb/s signaling rate); 2 USB 3.1 Gen 1 Type-A (Data Transfer Only); 1 AC smart pin; 1 HDMI 1.4; 1 headphone/microphone combo
32.4 x 22.29 x 2.05 cm
Starting at 1.58 kg
45 W AC power adapter
3-cell, 41 Wh Li-ion
Battery life mixed usage
Up to 13 hours and 15 minutes
Video Playback Battery life
Up to 8 hours and 45 minutes
B&O; Dual speakers; HP Audio Boost 1.0
- ${title}
- ${title}
- ${title}
- ${title}
HP Pavilion x360 - 14-dh1008nl Product Specifications
Pre-installed software
Netflix
Additional support options
- ${title}
- ${title}
- ${title}
Country/Region:
Thailand
- ${title}
hp-hero-support-search
- ${title}
