    Windows 11 Upgrade Guide
HP Notebook - 14s-cf1046tu Product Specifications
8LB26PA
Intel® Celeron® 4205U (1.8 GHz base frequency, 2 MB cache, 2 cores)
4 GB DDR4-2133 SDRAM (1 x 4 GB)
Video graphics
Intel® UHD Graphics 610
1 TB 5400 rpm SATA
14" diagonal HD SVA BrightView micro-edge WLED-backlit (1366 x 768)
Pointing device
Realtek RTL8723DE 802.11b/g/n (1x1) and Bluetooth® 4.2 combo
1 USB 3.1 Type-C™ Gen 1 (Data Transfer up to 5 Gb/s); 2 USB 3.1 Gen 1 (Data transfer only); 1 HDMI 1.4b. 1 RJ-45; 1 headphone/microphone combo
32.4 x 22.59 x 1.99 cm
Starting at 1.43 kg
45 W AC power adapter
3-cell, 41 Wh Li-ion
HP TrueVision HD Camera with integrated digital microphone
Dual speakers
HP Audio Switch; HP Documentation; HP ePrint; HP JumpStart; HP Support Assistant
