8LA47PA
HP ENVY x360 - 15-ds0041au
AMD Ryzen™ 5 3500U with Radeon™ Vega 8 Graphics (2.1 GHz base clock, up to 3.7 GHz max boost clock, 6 MB cache, 4 cores)
16 GB DDR4-2400 SDRAM (2 x 8 GB)
Video graphics
AMD Radeon™ Vega 8 Graphics
512 GB PCIe® NVMe™ M.2 SSD
15.6" diagonal FHD IPS anti-glare micro-edge WLED-backlit touch screen (1920 x 1080)
Realtek 802.11a/b/g/n/ac (2x2) and Bluetooth® 4.2 combo
1 USB 3.1 Gen 1 Type-C™ (5 Gb/s signaling rate, Power Delivery 3.0, DisplayPort™ 1.4, HP Sleep and Charge); 1 USB 3.1 Gen 1 Type-A (HP Sleep and Charge); 1 USB 3.1 Gen 1 Type-A (Data Transfer Only); 1 AC smart pin; 1 HDMI; 1 headphone/microphone combo
35.9 x 24.6 x 1.72 cm
Starting at 2.06 kg
65 W AC power adapter
4-cell, 55.67 Wh Li-ion prismatic
Bang & Olufsen, dual speakers, HP Audio Boost, HP Far-field Cortana support
- ${title}
- ${title}
- ${title}
- ${title}
HP ENVY x360 - 15-ds0041au Product Specifications
HP Audio Switch; HP Documentation; HP e-Service; HP JumpStart; HP Support Assistant; HP Connection Optimizer; HP Command Center; HP PC Hardware Diagnostics Windows
Pre-installed software
iQiyi
Additional support options
- ${title}
- ${title}
- ${title}
Country/Region:
Thailand
- ${title}
hp-hero-support-search
- ${title}
