6YU22PA
HP ENVY X360 - 13-ar0066au
AMD Ryzen™ 3 3300U with Radeon™ Vega 6 Graphics (2.1 GHz base clock, up to 3.5 GHz max boost clock, 6 MB cache, 4 cores)
AMD Integrated SoC
8 GB DDR4-2400 SDRAM (onboard)
Video graphics
AMD Radeon™ Vega 6 Graphics
128 GB M.2 SSD
Optical drive
Optical drive not included
13.3" diagonal FHD IPS BrightView micro-edge WLED-backlit multitouch-enabled edge-to-edge glass with Corning® Gorilla® Glass NBT™ (1920 x 1080)
802.11ac (2x2) Wi-Fi® and Bluetooth® 4.2 combo
1 USB 3.1 Gen 1 Type-C™ (5 Gb/s signaling rate, Power Delivery 3.0, DisplayPort™ 1.4, HP Sleep and Charge); 1 USB 3.1 Gen 1 Type-A (HP Sleep and Charge); 1 USB 3.1 Gen 1 Type-A (Data Transfer Only); 1 headphone/microphone combo
30.6 x 21.2 x 1.47 cm
Starting at 1.31 kg
65 W AC power adapter
4-cell, 53 Wh Li-ion polymer
Bang & Olufsen, quad speakers, HP Audio Boost
- ${title}
- ${title}
- ${title}
- ${title}
HP ENVY X360 - 13-ar0066au Product Specifications
HP Audio Switch; HP Documentation; HP e-Service; HP JumpStart; HP Support Assistant; HP Connection Optimizer; HP Command Center; HP PC Hardware Diagnostics Windows
Pre-installed software
iQiyi
Additional support options
- ${title}
- ${title}
- ${title}
Country/Region:
Thailand
- ${title}
hp-hero-support-search
- ${title}
