    Windows 11 Upgrade Guide
     Connect with HP support faster, manage all of your devices in one place, view warranty information and more. Sign up for an HP account
Document ID: c06427181
Version: 1
HP July 2019 BIOS Refresh (for 2018 Desktop PC)
Release date : 05-Aug-2019
Last updated : 05-Aug-2019
รายละเอียดการเปลี่ยนแปลง
Common changes for all platforms:
  • Fixes issue where BIOS update via F10 setup interface failed and report: "Internal error" when set schedule to daily/weekly/monthly.
  • Fixes issue where SystemDiags.log file created in FTP server after executing Remote HP PC Hardware Diagnostics.
  • Fixes issue where "Authentication Failed" screen displayed when enable BIOS password under F10 and Power-on Authentication in HPCSM, then uncheck "BIOS Administrator visible at Power-on Authentication" under F10 setup interface.
  • Fixes issue where display of TPM Firmware Update interface is cut off during update process.
  • Fixes issue where system booting delay when system installed with NVIDIA GeForce RTX 2070/2080 Graphics card.
  • Fixes issue where BIOS administrator account cannot be hidden in Power-On Authentication screen.
  • Adds an option in F10 setup to download and install BIOS updates automatically without prompts.
  • Adds a feature "Native OS Firmware Update Service" in F10 setup interface to enable/disable firmware update via Window Update service.
HP EliteOne 1000 G2 All-in-One System BIOS has the following enhancements added:
  • Fixes issue where "WHEA-Logger(Event ID 17)" occurred in Windows Event Viewer.
  • Adds a feature to separately control "Intel Management Engine (ME)" and "Intel Active Management (AMT)" individually.
  • Updates the Intel silicon reference code to 7.0.5C.50.
  • Updates Intel ME firmware to 12.0.39.1431.
  • Fixes issue where Serial COM11 device is disabled after RTC reset.
HP EliteDesk 800/880 G4 TWR/800 G4 SFF System BIOS has the following enhancements added:
HP EliteOne 800 G4 All-in-One System BIOS has the following enhancements added:
  • Fixes issue where panel flicker while displaying gray color on HPN 1840 BOE Panel.
HP EliteDesk 800 G4 DM System BIOS has the following enhancements added:
HP ProOne 600 G4 All-in-One System BIOS has the following enhancements added:
  • Updates VBIOS to enhance compatibility for new LGD panel.
HP ProDesk 600/680 G4 MT System BIOS has the following enhancements added:
HP ProDesk 600 G4 SFF System BIOS has the following enhancements added:
  • Update Intel ME firmware to 12.0.39.1431.
HP ProDesk 600 G4 DM System BIOS has the following enhancements added:
HP MP9 G4 Retail System BIOS has the following enhancements added:
HP Engage Flex Pro/Pro-C Retail System BIOS has the following enhancements added:
HP EliteDesk 705 G4 MT PC System BIOS has the following enhancements added:
  • Fixes issue where add-in VGA card shows yellow bang in device manger on Windows 7.
  • Updates AMD Pinnacle Ridge silicon reference code to 1.0.0.7.
  • Adds a feature "Hardware enabled Spectre Variant 2 Mitigation" in F10 setup interface to enable processor functionality that is used by some operating systems to mitigate the Spectre Variant 2 vulnerability.
  • Increase integrated video RAM dynamically when Hyper-V is enabled.
  • Fixes issue where system cannot update BIOS via F10 setup menu with USB drive.
  • Fixes issue where system displays intermittently blue screen with error code 0xEA in specific HW configuration.
  • Fixes issue where "Microsoft-Windows-Kernel-Power:137" occurred in Windows Event Viewer.
Effective Date: 2019-08-12
HP EliteDesk 705 G4 SFF PC System BIOS has the following enhancements added:
  • Increases integrated video RAM dynamically when Hyper-V is enabled.
HP EliteDesk 705 G4 DM System BIOS has the following enhancements added:
  • Fixes issue where system cannot do BIOS recovery via SATA hard drive.
COMPONENT VERSION
  • HP EliteOne 1000 G2 All-in-One System BIOS 02.08.00
  • HP EliteDesk 800/880 G4 TWR / 800 G4 SFF System BIOS 02.08.00
  • HP EliteOne 800 G4 All-in-One System BIOS 02.08.00
  • HP EliteDesk 800 G4 DM System BIOS 02.08.00
  • HP ProOne 600 G4 All-in-One System BIOS 02.08.00
  • HP ProDesk 600/680 G4 MT System BIOS 02.08.00
  • HP ProDesk 600 G4 SFF System BIOS 02.08.00
  • HP ProDesk 600 G4 DM System BIOS 02.08.00
  • HP MP9 G4 Retail System BIOS 02.08.00
  • HP Engage Flex Pro/Pro-C Retail System BIOS 02.08.00
  • HP EliteDesk 705 G4 MT System BIOS 02.08.01
  • HP EliteDesk 705 G4 SFF System BIOS 02.08.00
  • HP EliteDesk 705 G4 DM System BIOS 02.08.00
REASON FOR CHANGE
Regular quarterly release.
IMPACT OF CHANGE
No impact of change.
Components affected:
System BIOS
DATE OF CHANGE
Effective date : 07-Aug-2019
Hardware platforms affected : HP EliteDesk 705 35W G4 Desktop Mini PC, HP EliteDesk 705 65W G4 Desktop Mini PC, HP EliteDesk 705 G4 Microtower PC, HP EliteDesk 705 G4 Small Form Factor PC, HP EliteDesk 800 G4 Small Form Factor PC, HP EliteDesk 800 G4 Tower PC, HP EliteDesk 880 G4 Tower PC, HP EliteOne 1000 G2 23.8-in All-in-One Business PC, HP EliteOne 1000 G2 34-in Curved All-in-One Business PC, HP EliteOne 800 G4 23.8-inch Non-Touch All-in-One PC, HP EliteOne 800 G4 23.8-inch Touch All-in-One PC, HP Engage Flex Pro Retail System, HP Engage Flex Pro-C Retail System, HP MP9 G4 Retail System, HP ProDesk 600 G4 Desktop Mini PC, HP ProDesk 600 G4 Microtower PC, HP ProDesk 600 G4 Small Form Factor PC, HP ProDesk 680 G4 Microtower PC, HP ProOne 600 G4 21.5-inch Non-Touch All-in-One Business PC, HP ProOne 600 G4 21.5-inch Touch All-in-One Business PC
