Document ID: c06417547
Version: 1
HP EliteBook 830 G5 Notebook PC - SCCM Encounters DISM Error 1168 When Configuring Realtek HD Audio Driver
Release date : 22-Jul-2019
Last updated : 23-Jul-2019
DESCRIPTION
When using Microsoft System Center Configuration Manager (SCCM) to configure systems in the SCOPE, the following DISM error occurs:
Error: 1168.
Element Not Found.
This occurs when the Microsoft Deployment Image Servicing and Management (DISM) command tool executes commands to configure the Realtek HD Audio driver (SoftPaq SP95193). The issue occurs because the driver includes a Universal Windows Platform (UWP) component that is not being handled properly.
SCOPE
Computers:
Operating Systems:
Microsoft Windows 10 RS5 (Version 1809)
RESOLUTION
Below are the steps necessary to install this component with SCCM.
  1. Extract SoftPaq .
  2. Add a batch file to install the UWP component with DISM. Here is the DISM command to insert into the batch file:
    @echo ON dism.exe /image:%OSD_System%\ /add-Driver /Driver:%~dp0HSA\cb68d18decd44cd44c94bec5cd2a2c354180.appxbundle /Region="all" /LicensePath:%~dp0HSA\cb68d18decd44cd44c94bec5cd2a2c354180_License1.xml /DependencyPackagePath:%~dp0HSA \Micrsooft.VCLibs.140.00_14.0.26706.0_x64_8wekyb3d8bbwe.appx
    The variable %OSD_System%, used in the command above, is set by the partitioning step previous in the task sequence.
  3. Create a package and add a command line step to execute the batch file right after windows image, and before Apply Windows Settings.
  4. Deploy the task sequence and use Device Manager to verify that the Realtek Audio driver is installed.
Hardware platforms affected : HP EliteBook 830 G5 Notebook PC
Support Communication Cross Reference ID : IA06417547
