OMEN X by HP 15-dg0000ns Product Specifications
6WR73EA
Intel® Core™ i7 9750H (2.6 GHz base frequency, up to 4.5 GHz base with Intel® Turbo Boost Technology, 12 MB cache, 6 cores)
Intel® HM370
32 GB DDR4-2666 SDRAM (2 x 16 GB)
512 GB PCIe® NVMe™ M.2 SSD
Optical drive
Optical drive not included
39.6 cm (15.6") diagonal FHD 144 Hz IPS anti-glare micro-edge WLED-backlit (1920 x 1080); 15.18 cm (5.98") diagonal FHD IPS BrightView micro-edge WLED-backlit multitouch-enabled edge-to-edge glass (1920 x 1080)
2 M.2 PCIe® x4
1 USB 3.1 Gen 2 Type-C™ with Thunderbolt™ 3 (40 Gb/s signaling rate, Power Delivery 3.0, DisplayPort™ 1.4, HP Sleep and Charge); 3 USB 3.1 Gen 1 Type-A (HP Sleep and Charge); 1 RJ-45; 1 headphone/microphone combo; 1 microphone; 1 AC smart pin
36.21 x 26.17 x 2 cm
2.46 kg
230 W AC power adapter
6-cell, 72 Wh Li-ion polymer
B&O; dual speakers; HP Audio Boost; Omen Audio Control Support DTS:X® Ultra
OMEN Command Center; HP 3D DriveGuard; HP Audio Switch; HP JumpStart; HP Support Assistant
Pre-installed software
Netflix
