Model name
HP Smart Tank 514 Wireless All-in-One
3YW74A
- ${title}
- ${title}
- ${title}
- ${title}
Product Specifications for the HP Smart Tank 514 Wireless All-in-One (3YW74A)
Product naming
What's included and accessories
What's in the box
HP Smart Tank 514; Two HP GT53XL Black Original Ink Bottles; HP GT52 Cyan Original Ink Bottle; HP GT52 Magenta Original Ink Bottle; HP GT52 Yellow Original Ink Bottle; Ink caution flyer; Setup guide; Reference guide; Regulatory flyer; Warranty card, Power cord [For more information about fill and yield, see http://www.hp.com/go/learnaboutsupplies]
Connectivity
Ports
Hi-Speed USB 2.0, Wi-Fi, Bluetooth LE
Wireless capability
Yes, built-in dual band Wi-Fi 802.11b/g/n, Wireless direct, BLE
Copy
Copier settings
Number of Copies, Resize, Quality, Lighter/Darker, Papersize, Papertype, ID Copy, Enhancement
Color copy capability
Yes
Maximum number of copies
Up to 99 copies
Copy resolution
Up to 600 dpi
Environmental
Acoustic power emissions (active, printing)
6.5 B(A)
Acoustic pressure emissions
51 dB
Recommended operating humidity range
20 to 80% RH
Non-Operating Humidity Range
5 to 90% RH (non-condensing)
Recommended operating temperature range (Celsius)
15 to 30°C
Recommended operating temperature range (Fahrenheit)
59 to 86°F
Storage temperature range (Celsius)
-40 to 60°C
Storage temperature range (Fahrenheit)
-40 to 140°F
Environmental specifications
No
Fax
Telephone handset supported
No
Memory
Memory
256 MB; Integrated memory
Maximum Memory
256 MB
Memory card compatibility
No
Mobile printing capability
Mobile printing services
HP Smart app; Apple AirPrint™; Fire™; Google Cloud Print 2.0; HP ePrint; Android printing; Mopria™-certified
Networking
Network protocols, supported
9100, SNMP, SLP, IPP, WS-Print, Wireless, LPR
Paper handling
Input capacity
Up to 100 sheets
Standard input capacity (cards)
Up to 30 cards
Standard input capacity (envelopes)
Up to 10
Output capacity
Up to 30 sheets
Media sizes supported (metric)
A4; B5; A6; DL envelope, legal
Media sizes supported (U.S. standard)
Letter; legal; 4 x 6 in; 5 x 7 in; 8 x 10 in; No. 10 envelopes
Media sizes, custom (metric)
76.2 x 127 to 215.9 x 355.6 mm
Media sizes, custom (U.S. standard)
3 x 5 in to 8.5 x 14 in
Media types
Plain paper, Matte Brochure Papers, Glossy Brochure Papers, Photo papers, Envelopes
Media weight supported (metric)
Plain paper: 60 to 90 g/m²; Envelopes: 75 to 90 g/m²; Cards: up to 200 g/m²; Photo paper: up to 300 g/m²
Media weight supported (U.S. standard)
20 lb
Borderless printing
Yes (up to 8.5 x 11 in, 210 x 297 mm)
Paper handling - duplexer
Media sizes, duplex (U.S. standard)
Letter; Executive
Physical dimensions
Maximum dimensions (W x D x H, metric)
449 x 605.65 x 258.7 mm
Maximum dimensions (W x D x H, U.S. standard)
17.7 x 23.8 x 10.18 in
Weight (metric)
5.14 kg
Weight (U.S. standard)
11.31 lb
Power
Energy savings feature technology
HP Auto-Off Technology
Internal built in
Power supply
Input voltage 100 to 240 VAC (+/- 10%), 50/60 Hz (+/- 3 Hz). High voltage: Input voltage 200 to 240 VAC (+/- 10%), 50/60 Hz (+/- 3Hz)
Power consumption
0.12 watts (manual-Off), 3.12 watts (ready), 0.75 watt (sleep)
Print cartridges
Number of print cartridges
4 (1 each black bottle, set of 3 color bottles)
Replacement cartridges
HP GT53 90-ml Black Original Ink Bottle 1VV22AL; HP GT52 Cyan Original Ink Bottle M0H54AL; HP GT52 Magenta Original Ink Bottle M0H55AL; HP GT52 Yellow Original Ink Bottle M0H56AL; HP GT52 3-pack Cyan/Magenta/Yellow Original Ink Bottles X4E44AL. For more information about fill and yield, see http://www.hp.com/go/learnaboutsupplies
Printing specifications
Print technology
HP Thermal Inkjet
Duplex printing
Manual (driver support provided)
Print speed (black, draft, Letter)
Up to 22 ppm
Print speed (color, draft, Letter)
Up to 16 ppm
Print speed black (ISO)
Up to 11 ppm
Print speed color (ISO)
Up to 5 ppm
Print resolution (best)
Up to 1200 x 1200 rendered dpi
Maximum print area (metric)
216 x 355 mm
Monthly duty cycle
Up to 1000 pages
Print languages
HP PCL 3 GUI
Regulatory specifications
Regulatory model number
SNPRC-1804-01
Safety
IEC 60950-1 & IEC 62368-1 compliant; EU LVD and EN 60950 & EN 62368 compliant; UL GS approved; Singapore Safety; Russia EAC; China CCC; Taiwan BSMI
Electromagnetic compatibility
CISPR 32:2015/EN 55032:2015 Class B; CISPR24:2010/EN 55024:2010; EN 61000-3-2:2014; EN 61000-3-3:2013; EN 301 489-1 V2.1.1:2017; EN 301 489-17 V3.1.1:2017 GB4943.1-2011, GB/T9254-2008, GB17625.1-2012 (CCC China); CNS14336-1, CNS13438 & CNS15663 (BSMI RoHS -Taiwan); EAC (Russia)
Telecom compliance (fax capability)
EN 300 328 V2.1.1:2016; EN 301 893 V2.1.0:2017
Scan
Scan technology
Contact Image Sensor (CIS)
Scan speed (normal)
Up to 3 ppm color; up to 5 ppm, mono
Scan resolution, hardware
Up to 1200 x 1200 dpi
Levels of grayscale
256
Bit depth
24-bit
Scanning options (ADF)
Not Applicable
Maximum flatbed scan size (metric)
216 x 297 mm
Maximum flatbed scan size (U.S. standard)
8.5 x 11.69 in
Twain version
Version 2.1
Security
Security management
No
System requirements
Minimum system requirements for Windows
Windows 10, 8, Windows 7 Service Pack 1 (SP1): 32-bit or 64-bit, 2 GB available hard disk space, Internet connection, USB port, Internet Explorer.
Recommended system requirements for Windows
Minimum System Requirements for Macintosh
OS X v10.11 El Capitan and above, Internet Access
Recommended Macintosh system requirements
Operating system (supported note)
Windows 10, 8, Windows 7 Service Pack 1 (SP1); OS X v10.11 El Capitan, macOS Sierra v10.12 (previously OS X), macOS High Sierra v10.13, macOS Mojave v10.14
One year of 24/7 world-class technical support services through http://www.hp.com/support; One-year or 30,000 pages limited hardware warranty, whichever is earlier from the date of purchase; user replaceable parts have separate warranty periods
Additional support options
- ${title}
- ${title}
- ${title}
Country/Region:
Thailand
- ${title}
hp-hero-support-search
- ${title}
