    Windows 11 Upgrade Guide
     Connect with HP support faster, manage all of your devices in one place, view warranty information and more. Sign up for an HP account
HP Pavilion x360 14-dh0055tx Product Specifications
6YY90PA
Intel® Core™ i7-8565U (1.8 GHz base frequency, up to 4.6 GHz with Intel® Turbo Boost Technology, 8 MB cache, 4 cores)
Intel® Integrated SoC
Video graphics
NVIDIA® GeForce® MX250 (2 GB GDDR5 dedicated)
256 GB PCIe® NVMe™ M.2 SSD
Optical drive
Optical drive not included
14" diagonal FHD IPS micro-edge WLED-backlit multitouch-enabled edge-to-edge glass (1920 x 1080)
Realtek 802.11b/g/n/a/ac (2x2) and Bluetooth® 4.2 combo
1 USB 3.1 Gen 1 Type-C™ (Data Transfer Only, 5 Gb/s signaling rate); 2 USB 3.1 Gen 1 Type-A (Data Transfer Only); 1 AC smart pin; 1 HDMI; 1 headphone/microphone combo;
32.4 x 22.29 x 2.05 cm
Starting at 1.59 kg
65 W AC power adapter
3-cell, 41 Wh Li-ion
HP 3D DriveGuard; HP Audio Switch; HP CoolSense; HP Documentation; HP JumpStart; HP Support Assistant; HP Connection Optimizer; HP Privacy Settings
