    Windows 11 Upgrade Guide
     Connect with HP support faster, manage all of your devices in one place, view warranty information and more. Sign up for an HP account
HP Gaming Pavilion - 15-dk0042tx Product Specifications
7LJ56PA
Intel® Core™ i7-9750H (2.6 GHz base frequency, up to 4.5 GHz base with Intel® Turbo Boost Technology, 12 MB cache, 6 cores)
Intel® HM370
Video graphics
NVIDIA® GeForce® GTX 1650 Graphics (4 GB GDDR5 dedicated)
1 TB 7200 rpm SATA
15.6" diagonal FHD IPS anti-glare micro-edge WLED- backlit (1920 x 1080)
1 USB 3.1 Gen 2 Type-C™ (10 Gb/s signaling rate, Power Delivery 3.0, DisplayPort™ 1.4, HP Sleep and Charge); 1 USB 3.1 Gen 1 Type-A (HP Sleep and Charge); 2 USB 3.1 Gen 1 Type-A (Data Transfer Only); 1 HDMI; 1 AC smart pin; 1 RJ-45; 1 headphone/microphone combo
36 x 25.6 x 2.34 cm
Starting at 2.23 kg
150 W AC power adapter
3-cell, 52.5 Wh Li-ion
HP 3D DriveGuard; HP Audio Switch; HP Documentation; HP e-Service; HP JumpStart; HP Support Assistant; HP Connection Optimizer; HP PC Hardware Diagnostics Windows; HP BIOS Recovery
Pre-installed software
iQiyi
