    Coronavirus (COVID-19) Impact
    We are experiencing longer than expected wait times to reach an agent. Please use the resources here on our HP Support website to answer your questions and troubleshoot any issues you may be experiencing.  Try our Virtual Agent and Diagnostic Tools for faster service.
    Are you working from home?
OMEN by HP - 15-dc0059np Product Specifications
7MY00EA
Intel® Core™ i5 8300H (2.3 GHz base frequency, up to 4 GHz base with Intel® Turbo Boost Technology, 8 MB cache, 4 cores)
Intel® HM370
256 GB PCIe® NVMe™ M.2 SSD
Optical drive
Optical drive not included
39.6 cm (15.6") diagonal FHD IPS anti-glare micro-edge WLED-backlit (1920 x 1080)
1 USB 3.1 Gen 2 Type-C™ (5 Gb/s signaling rate, DisplayPort™ 1.2, HP Sleep and Charge); 3 USB 3.1 Gen 1 (1 HP Sleep and Charge); 1 HDMI; 1 RJ-45; 1 Mini DisplayPort™; 1 headphone/microphone combo; 1 microphone
36 x 26.3 x 2.5 cm
2.38 kg
135 W AC power adapter
4-cell, 70 Wh Li-ion
Battery life mixed usage
Up to 13 hours
Video Playback Battery life
Up to 8 hours and 15 minutes
Bang & Olufsen, dual speakers, HP Audio Boost, DTS Headphone:X™ support
OMEN Command Center; HP Audio Switch; HP CoolSense; HP JumpStart
Pre-installed software
Netflix
