    Apache Log4j Update
HP Chromebook - 15-de0550nd Product Specifications
6SW62EA
Intel® Core™ i5 8250U (1.6 GHz base frequency, up to 3.4 GHz with Intel® Turbo Boost Technology, 6 MB cache, 4 cores)
Intel® Integrated SoC
8 GB DDR4-2133 SDRAM (onboard)
Video graphics
Intel® UHD Graphics 620
128 GB eMMC
Optical drive
Optical drive not included
39.6 cm (15.6") diagonal FHD IPS micro-edge WLED-backlit touch screen (1920 x 1080)
Intel® Wireless-AC 7265 802.11ac (2x2) Wi-Fi® and Bluetooth® 4.2 Combo
1 microSD media card reader
2 USB 3.1 Gen 1 Type-C™ (5 Gb/s signaling rate, Power Delivery 3.0, HP Sleep and Charge); 1 USB 3.1 Gen 1 Type-A (HP Sleep and Charge)
35.8 x 24.6 x 1.79 cm
1.81 kg
45 W AC power adapter
3-cell, 60 Wh Li-ion polymer
Battery life mixed usage
Up to 13 hours
B&O, dual speakers
Chrome OS™
