    Coronavirus (COVID-19) Impact
    We are experiencing longer than expected wait times to reach an agent. Please use the resources here on our HP Support website to answer your questions and troubleshoot any issues you may be experiencing.  Try our Virtual Agent and Diagnostic Tools for faster service.
    Are you working from home?
HP 340 and 348 G5 Notebook PC Specifications
Product image
Operating systems
Specification
Preinstalled
Windows 10 Pro 64 (National Academic only)
Some devices for academic use automatically update to Windows 10 Pro Education with the Windows 10 Anniversary Update. Features vary.
Windows 10 Pro 64
Not all features are available in all editions or versions of Windows. Systems might require upgraded and/or separately purchased hardware, drivers, software or BIOS update to take full advantage of Windows functionality. Windows 10 automatic updates are always enabled. ISP fees might apply and additional requirements might apply over time for updates.
FreeDOS 1.2
In accordance with Microsoft support policy, HP does not support the Windows 8 or Windows 7 operating system on products configured with Intel and AMD 7th generation or later processors, or provide any Windows 8 or Windows 7 drivers.
Processors
Specification
Intel Core i7-8565U processor
1.8 GHz base frequency, up to 4.6 GHz with Intel Turbo Boost Technology
8 MB cache and 4 cores
Intel UHD Graphics 620
Intel Core i5-8265U processor
1.6 GHz base frequency, up to 3.9 GHz with Intel Turbo Boost Technology
6 MB cache and 4 cores
Intel Core i3-8145U processor
2.1 GHz base frequency, up to 3.9 GHz with Intel Turbo Boost Technology
4 MB cache and 2 cores
Intel Core i3-7020U processor
2.3 GHz base frequency
3 MB cache and 2 cores
Integrated with processor
Multicore is designed to improve performance of certain software products. Not all customers or software applications necessarily benefit from use of this technology. Performance and clock frequency vary depending on application workload and hardware and software configurations. Intel numbering is not a measurement of higher performance.
Processor speed denotes maximum performance mode; processors run at lower speeds in battery optimization mode.
Graphics
Specification
Integrated
High-definition (HD) content is required to view high definition images.
Discrete
AMD Radeon 530 (2 GB GDDR5 dedicated)
AMD Dynamic Switchable Graphics technology requires an Intel processor, plus an AMD Radeon discrete graphics configuration and is not available on FreeDOS and Linux OS. With AMD Dynamic Switchable Graphics technology, full enablement of all discrete graphics video and display features might not be supported on all systems.
Supports
HD decode
DirectX 12
HDMI 1.4b
Specification
Non-touch
35.56 cm (14.0 in) diagonal HD SVA eDP anti-glare WLED-backlit slim-flat, 220 cd/m2, 45% sRGB for one WLAN antenna (1366 x 768)
35.56 cm (14.0 in) diagonal HD SVA eDP anti-glare WLED-backlit slim-flat, 220 cd/m2, 45% sRGB for two WLAN antennas (1366 x 768)
35.56 cm (14.0 in) diagonal FHD IPS eDP anti-glare WLED-backlit slim-flat, 250 cd/m2, 45% sRGB for one WLAN antenna (1920 x 1080)
35.56 cm (14.0 in) diagonal FHD IPS eDP anti-glare WLED-backlit slim-flat, 250 cd/m2, 45% sRGB for two WLAN antennas (1920 x 1080)
Resolutions are dependent upon monitor capability, and resolution and color depth settings.
Storage/drives
Specification
Primary M.2 Solid State Drive storage
512 GB PCIe NVMe Value SSD
256 GB PCIe NVMe Value TLC SSD
256 GB PCIe NVMe TLC SSD
256 GB SATA-3 TLC SSD
128 GB SATA-3 TLC SSD
Primary SATA Hard drives
1 TB 5400 RPM
500 GB 7200 RPM
16 GB memory cache Intel Optane (only available with HDD to optimize HDD performance)
For solid state drives or hard drives, GB = 1 billion bytes. TB = 1 trillion bytes. Actual formatted capacity is less. Up to 30 GB (for Windows 10) is reserved for system recovery software.
Memory
Specification
Standard
DDR4-2400 SDRAM (only available for 8th Generation Intel processors)
DDR4-2133 SDRAM
Supports dual-channel memory
(2) Dual-channel SODIMM slots (both slots are customer accessible/upgradable)
Configurations
32 GB DDR4-2400 SDRAM (16 GB x 2)
16 GB DDR4-2400 SDRAM (16 GB x 1)
8 GB DDR4-2400 SDRAM (8 GB x 1)
4 GB DDR4-2400 SDRAM (4 GB x 1)
32 GB DDR4-2133 SDRAM (16 GB x 2)
16 GB DDR4-2133 SDRAM (16 GB x 1)
8 GB DDR4-2133 SDRAM (8 GB x 1)
4 GB DDR4-2133 SDRAM (4 GB x 1)
Maximum
32 GB
Due to the non-industry standard nature of some third-party memory modules, we recommend HP branded memory to ensure compatibility. If memory speeds are mixed, the system performs at the lower memory speed.
Ports/slots
Specification
Ports
(1) USB 3.1 Type-C connector
(2) USB 3.1 Gen 1
(1) HDMI 1.4b
(1) RJ-45/Ethernet port
(1) Headphone/microphone combo jack
(1) AC power port
HDMI cable sold separately.
Slot
(1) SD Card reader
Supports SD, SDHC, and SDXC.
Networking/communication
Specification
Wireless LAN (WLAN)
Intel Dual Band Wireless-AC 9560 802.11ac (2x2) WLAN and Bluetooth 5 Combo, non-vPro
Realtek 802.11ac (1x1) WLAN and Bluetooth 4.2 Combo
Realtek 802.11b/g/n (1x1) WLAN and Bluetooth 4.2 Combo
Wireless access point and Internet service is required and is not included. Availability of public wireless access points limited. The specifications for the 802.11ac WLAN are draft specifications and are not final. If the final specifications differ from the draft specifications, it might affect the ability of the notebook to communicate with other 802.11ac WLAN devices.
Ethernet
Realtek RTL8111HSH-CG 10/100/1000 GbE NIC
Integrated 10/100/1000 GbE
The term "10/100/1000" or "Gigabit" Ethernet indicates compatibility with IEEE standard 802.3ab for Gigabit Ethernet, and does not connote actual operating speed of 1 Gb/s. For high-speed transmission, connection to a Gigabit Ethernet server and network infrastructure is required.
Audio/multimedia
Specification
Audio
(2) Integrated stereo speakers
Integrated dual-array microphone
Camera
720p HD camera
Sold separately or as an optional feature.
Keyboards/pointing devices/function keys
Specification
HP Premium keyboard
Full-size island-style spill resistant keyboard
Pointing device
Clickpad with multi-touch gesture support
Function keys
Function keys
ESC – System Information
F1 – Windows Help
F2 – Brightness down
F3 – Brightness up
F4 – Display switching
F5 – Blank
F6 – Speaker mute
F7 – Volume down
F8 – Volume up
F9 – Previous track/section
F10 – Starts, pauses, or resumes playback
F11 – Next track/section
F12 – Airplane mode (Wireless feature on or off)
Software/security
Specification
Preinstalled software
HP ePrint (requires Internet access)
HP Recovery Manager
Native Miracast Support
HP Support Assistant (requires Windows and Internet access)
sMedio True DVD for HP
Security
Trusted Platform Module (TPM)
Common Criteria EAL4+ Certified
Windows Defender
Power
Specification
Power supply
Adapters
HP Smart 65 W External AC power adapter
HP Smart 65 W EM External AC power adapter
HP Smart 45 W External AC power adapter
Power cords
3-wire plug - 1 m (3.28 ft)
3-wire plug - 1.8 m (5.9 ft)
Availability might vary by country/region.
Primary battery
HP Long Life 3-cell, 41 Wh Li-ion
Battery is internal and not replaceable by customer.
Battery life
Up to 12 hours and 15 minutes (UMA, WHL-U processor, HD display, 4 GB x 1 memory, and SSD)
Windows 10 MM14 battery life varies depending on various factors including product model, configuration, loaded applications, features, use, wireless functionality, and power management settings. The maximum capacity of the battery naturally decreases with time and usage.
Physical specifications
Specification
Starting at 1.48 kg (3.26 lb)
Weight varies by configuration and components.
Dimensions (W x D x H)
22.58 x 32.41 x 19.89 cm (8.89 x 12.76 x 7.83 in)
