    We are upgrading our website
    Fix Windows 10 Update Issues
HP Pavilion x360 14-dh0006tx Product Specifications
6MY84PA
Intel® Core™ i5 8265U (1.6 GHz base frequency, up to 3.9 GHz with Intel® Turbo Boost Technology, 6 MB cache, 4 cores)
Intel® Integrated SoC
256 GB PCIe® NVMe™ M.2 SSD
14" diagonal FHD IPS anti-glare WLED-backlit touch screen (1920 x 1080)
Realtek 802.11 a/b/g/n/ac (1x1) and Bluetooth® 4.2 Combo
1 USB 3.1 Gen 1 Type-C™ (Data Transfer Only, 5 Gb/s signaling rate); 2 USB 3.1 Gen 1 Type-A (Data Transfer Only); 1 AC smart pin; 1 HDMI; 1 headphone/microphone combo;
32.4 x 22.29 x 1.97 cm
Starting at 1.59 kg
65 W AC power adapter
3-cell, 41 Wh Li-ion
HP 3D DriveGuard; HP Audio Switch; HP CoolSense; HP Documentation; HP JumpStart; HP Support Assistant; HP Connection Optimizer; HP Privacy Settings
