    Fix Windows 10 Update Issues
    Are you working from home?
HP Notebook - 15-dw0039nf Product Specifications
6HX49EA
Intel® Core™ i5 8265U (1.6 GHz base frequency, up to 3.9 GHz with Intel® Turbo Boost Technology, 6 MB cache, 4 cores)
Intel® Integrated SoC
Video graphics
Intel® UHD Graphics 620
256 GB PCIe® NVMe™ M.2 SSD
Optical drive
Optical drive not included
39.6 cm (15.6") diagonal HD SVA anti-glare micro-edge WLED-backlit (1366 x 768)
Realtek 802.11b/g/n/a/ac (2x2) and Bluetooth® 4.2 combo
1 USB 3.1 Gen 1 Type-C™ (Data Transfer Only, 5 Gb/s signaling rate); 2 USB 3.1 Gen 1 Type-A (Data Transfer Only); 1 RJ-45; 1 AC smart pin; 1 HDMI; 1 headphone/microphone combo
35.85 x 24.2 x 1.99 cm
1.74 kg
45 W AC power adapter
3-cell, 41 Wh Li-ion
Battery life mixed usage
Up to 12 hours and 15 minutes
Video Playback Battery life
Up to 10 hours and 30 minutes
HP TrueVision HD Camera with integrated dual array digital microphone
Dual speakers
Pre-installed software
Netflix
