Use the printer control panel to scan a document directly to a SharePoint site.
note:Scan to SharePoint is not supported with SharePoint 365.
In order to use the Scan to SharePoint feature, the printer must be connected to a network and the Scan to SharePoint feature must be configured by using the HP Embedded Web Server. For instructions on configuring the feature, go to Set up Scan to SharePoint.
