HP Notebook - 15s-du0008tx Product Specifications
6MZ26PA
Intel® Core™ i3-7020U (2.3 GHz, 3 MB cache, 2 cores)
Intel® Integrated SoC
4 GB DDR4-2133 SDRAM (1 x 4 GB)
1 TB 5400 rpm SATA
Optical drive
Optical drive not included
15.6" diagonal FHD IPS anti-glare micro-edge WLED-backlit (1920 x 1080)
802.11b/g/n (1x1) Wi-Fi® and Bluetooth® 4.2 combo
1 HDMI; 1 headphone/microphone combo; 1 RJ-45; 1 USB 3.1 Type-C™ Gen 1 (Data Transfer up to 5 Gb/s); 2 USB 3.1 Gen 1 (Data transfer only); 1 USB 3.1 Type-C™ Gen 1 (Data Transfer Only, 5 Gb/s signaling rate); 1 AC smart pin
35.85 x 24.2 x 1.99 cm
Starting at 1.74 kg
65 W AC power adapter
3-cell, 41 Wh Li-ion
HP TrueVision HD Camera with integrated digital microphone
Dual speakers
HP Audio Switch; HP Documentation; HP ePrint; HP JumpStart; HP Support Assistant
