    Fix Windows 10 Update Issues
HP Pavilion 14-ce2006tx Product Specifications
6MU67PA
Intel® Core™ i5 8265U (1.6 GHz base frequency, up to 3.9 GHz with Intel® Turbo Boost Technology, 6 MB cache, 4 cores)
Intel® Integrated SoC
  • 1 TB 5400 rpm SATA
  • 256 GB PCIe® NVMe™ M.2 SSD
14" diagonal FHD IPS BrightView WLED-backlit (1920 x 1080)
Intel® Wireless-AC 9461 802.11a/b/g/n/ac (1x1) Wi-Fi® and Bluetooth® 5 Combo
1 USB 3.1 Gen 1 Type-C™ (Data Transfer Only, 5 Gb/s signaling rate); 2 USB 3.1 Gen 1 Type-A (Data Transfer Only); 1 RJ-45; 1 AC smart pin; 1 HDMI; 1 headphone/microphone combo
32.68 x 22.55 x 1.79 cm
Starting at 1.6 kg
65 W AC power adapter
3-cell, 41 Wh Li-ion
HP Audio Switch; HP CoolSense; HP Documentation; HP ePrint; HP JumpStart; HP Support Assistant; HP Connection Optimizer; HP BIOS Recovery
