HP LaserJet Managed MFP E62655, E62665, HP LaserJet Managed Flow MFP E62665, E62675 - Printer views
Printer front view
    Figure : Printer front view
  1. Control panel with color touchscreen display (tilts up for easier viewing)
  2. Document-feeder input tray
  3. Document-feeder output bin
  4. Document-feeder output extension (extend this when scanning longer—such as legal—paper)
  5. Scanner assembly
  6. Right door (access for clearing jams)
  7. Tray 1 (multipurpose tray)
  8. Formatter (contains the interface ports)
  9. Slot for a cable-type security lock
  10. Power connection
  11. Tray 2
  12. On/off button
  13. Walk-up USB port
  14. Output bin
  15. Output bin extension
  16. 1 x 550-sheet paper feeder with stand (optional accessory)
  17. 3 x 550-sheet paper feeder with stand (optional accessory)
  18. 900-sheet 3-bin Stapling Mailbox (E62665hs, E62665z, E62675z models only)
  19. Hardware integration pocket (for connecting accessories and third-party devices)
  20. Keyboard (E62665z, E62675z models only). Pull the keyboard straight out to use it.Close the keyboard when it is not in use.
  21. Stapler door (E62665hs, E62665z, E62675z models only)
  22. 1 x 550-sheet feeder plus 2,100-sheet high-capacity feeder (optional accessory)
Printer back view
    Figure : Printer rear view
  1. Document feeder cover release latch
  2. Document-feeder cover (access for clearing jams)
  3. Cartridge door release button
  4. Cartridge door (access to the toner cartridge)
  5. Serial number and product number label
Interface ports
    Figure : Interface ports
  1. Host USB port for connecting external USB devices (this port might be covered)For easy-access USB printing, use the USB port near the control panel.
  2. Hi-Speed USB 2.0 printing port
  3. Local area network (LAN) Ethernet (RJ-45) network port
  4. Fax port (fax models only)
Control-panel view
The Home screen provides access to the printer features and indicates the current status of the printer.
Return to the Home screen at any time by touching the Home button on the left side of the printer control panel, or touch the Home button in the upper-left corner of most screens.
For more information about the printer-control-panel features, go to www.hp.com/support/ljE62655mfp, www.hp.com/support/ljE62665mfp, or www.hp.com/support/ljE62675mfp Select Manuals, and then select General reference.
The features that appear on the Home screen can vary, depending on the printer configuration.
    Figure : Printer control panel
  1. Home button
  2. Applications area
  3. Reset button
  4. Sign In or Sign Out button
  5. Information button
  6. Help button
  7. Current time
  8. Start Copy button
  9. Copy count
  10. Home-screen page indicator
  11. Keyboard(Flow models only)
  12. Easy-access USB port
  13. Hardware integration pocket (HIP)
How to use the touchscreen control panel
Use the following actions to use the printer touchscreen control panel.
Action
Example
Touch
Touch an item on the screen to select that item or open that menu. Also, when scrolling through menus, briefly touch the screen to stop the scrolling.
Touch the Settings icon to open the Settings app.
Swipe
Touch the screen and then move your finger horizontally to scroll the screen sideways.
Swipe until the Settings app displays.
Scroll
Touch the screen and then move your finger vertically to scroll the screen up and down. When scrolling through menus, briefly touch the screen to stop the scrolling.
Scroll through the Settings app.
