    Fix HP Printer issue on macOS
HP LaserJet E62655, E62665, E62665, E62675 - Printer specifications
The following specifications are correct at the time of publication, but they are subject to change. For current information, see www.hp.com/support/ljE62655mfp, www.hp.com/support/ljE62665mfp, or www.hp.com/support/ljE62675mfp.
Technical specifications
Product numbers
  • Model E62655dn - # 3GY14A
  • Model E62665hs - # 3GY15A
  • Model E62665h - # 3GY16A
  • Model E62665z - # 3GY17A
  • Model E62675z - # 3GY18A
Paper handling specifications
Paper handling features
Model E62655dn
Model E62665h, E62665hs
Model E62665z, E62675z
Tray 1 (100-sheet capacity)
Tray 2 (550-sheet capacity)
1 x 550-sheet paper feeder
These models accepts up to six optional 1 x 550-sheet feeders
Optional
Optional
Optional
1 x 550-sheet paper feeder with stand
Optional
Optional
Optional
1 x 550-sheet feeder plus 2,100-sheet high-capacity feeder
Optional
Optional
Optional
3 x 550-sheet paper feeder with stand
Optional
Optional
Optional
Envelope feeder cassette for printing up to 75 envelopes
Optional
Optional
Optional
900-sheet 3-bin Stapling Mailbox
Not supported
Included with E62665hs
Automatic duplex printing
Connectivity specifications
Connectivity features
Model E62655dn
10/100/1000 Ethernet LAN connection with IPv4 and IPv6
Hi-Speed USB 2.0
Easy-access USB port for printing without a computer and upgrading the firmware
Hardware Integration Pocket for connecting accessory and third-party devices
HP Internal USB Ports
Optional
Optional
Optional
HP Jetdirect 2900nw Print Server accessory for wireless connectivity
Optional
Optional
Optional
HP Jetdirect 3100w BLE/NFC/Wireless Accessory for printing from mobile devices
Connected via the Hardware Integration Pocket or the rear host USB port. The HP Jetdirect 3100w BLE/NFC/Wireless Accessory requires the HP Internal USB ports accessory.
Optional
Optional
Optional
Print specifications
Print features
Model E62655dn
Prints 52 pages per minute (ppm) on A4 and 55 ppm on letter-size paper
Not Supported
Not Supported
Prints 61 ppm on A4 and 65 ppm on letter-size paper
Not Supported
Included with E62665z
Prints 71 ppm on A4 and 75 ppm on letter-size paper
Not supported
Not supported
Included with E62675z
Easy-access USB printing (no computer required)
Store jobs in the printer memory to print later or print privately
Copy and Scan specifications
Copy and Scan features
Copy and scan speeds are subject to change. For the most current information, go to www.hp.com/support/ljE62655mfp, www.hp.com/support/ljE62665mfp, or www.hp.com/support/ljE62675mfp
Model E62655dn
Copies 52 pages per minute (ppm) on A4 and 55 ppm on letter-size paper
Not supported
Not supported
Copies 61 ppm on A4 and 65 ppm on letter-size paper
Not supported
Copies 71 ppm on A4 and 75 ppm on letter-size paper
Not supported
Not supported
Scans at 75 images per minute (ipm) (monochrome or color).
Not supported
Scans at 120 ipm (monochrome and color).
Not supported
Not supported
Easy-access USB copying and scanning (no computer required)
150-page document feeder with electronic duplex copying and scanning
HP EveryPage Technologies including ultrasonic multi-feed detection
Embedded optical character recognition (OCR) provides the ability to convert printed pages into text that can be edited or searched using a computer.
SMART Label feature provides paper-edge detection for automatic page cropping
Automatic page orientation for pages that have at least 100 characters of text.
Automatic tone adjustment sets contrast, brightness, and background removal for each page.
Digital Send specifications
Digital Send features
Model E62655dn
Send documents to email, USB, and shared folders on a network
Send documents to SharePoint®
Memory specifications
Memory features
Model E62655dn
1.75 GB base memory, expandable to 2.5 GB
Optional
Optional
Not supported
2.25 GB base memory, expandable to 3 GB
Not supported
Not supported
Optional
Other specifications
Other features
Model E62655dn
Touchscreen control panel
Retractable keyboard
Not supported
Not supported
Mass storage: 320 GB HP High-Performance Secure Hard Disk
Optional
Security: HP Trusted Platform Module for encrypting all data that passes through the printer
Fax
Optional
Optional
Optional
Supported operating systems
Linux: For information and print drivers for Linux, go to www.hp.com/go/linuxprinting.
UNIX: For information and print drivers for UNIX®, go to www.hp.com/go/unixmodelscripts.
The following information applies to the printer-specific Windows HP PCL 6 print drivers, HP print drivers for macOS, and to the software installer.
Windows: Download HP Easy Start from 123.hp.com/LaserJet to install the HP print driver. Or, go to the printer-support website for this printer: www.hp.com/support/ljE62655mfp, www.hp.com/support/ljE62665mfp, or www.hp.com/support/ljE62675mfp to download the print driver or the software installer to install the HP print driver.
macOS: Mac computers are supported with this printer. Download HP Easy Start either from 123.hp.com/LaserJet or from the Printer Support page, and then use HP Easy Start to install the HP print driver.
  1. Follow the steps provided to download the printer software.
Supported operating systems and print drivers
Print driver (for Windows, or the installer on the web for macOS)
Windows 7, 32-bit and 64-bit
The “HP PCL 6” printer-specific print driver is installed for this operating system as part of the software installation.
Windows 8, 32-bit and 64-bit
Windows 8.1, 32-bit and 64-bit
The “HP PCL-6” V4 printer-specific print driver is installed for this operating system as part of the software installation.
Windows 10, 32-bit and 64-bit
Windows Server 2008 R2, SP 1, 64-bit
The PCL 6 printer-specific print driver is available for download from the printer-support website. Download the driver, and then use the Microsoft Add Printer tool to install it.
Windows Server 2012, 64-bit
Windows Server 2012 R2, 64-bit
Windows Server 2016, 64-bit
macOS 10.12 Sierra, macOS 10.13 High Sierra
Download HP Easy Start from 123.hp.com/LaserJet, and then use it to install the print driver.
Supported operating systems can change.
For a current list of supported operating systems, go to www.hp.com/support/ljE62655mfp, www.hp.com/support/ljE62665mfp, or www.hp.com/support/ljE62675mfp for HP's all-inclusive help for the printer.
For details on client and server operating systems and for HP UPD driver support for this printer, go to www.hp.com/go/upd. Under Additional information, click the links.
Minimum system requirements
Windows
macOS
  • Internet connection
  • Dedicated USB 1.1 or 2.0 connection or a network connection
  • 2 GB of available hard-disk space
  • 1 GB RAM (32-bit) or 2 GB RAM (64-bit)
  • 1.5 GB of available hard-disk space
The Windows software installer installs the HP Smart Device Agent Base service. The file size is approximately 100 kb. Its only function is to check for printers connected via USB hourly. No data is collected. If a USB printer is found, it then tries to locate a JetAdvantage Management Connector (JAMc) instance on the network. If a JAMc is found, the HP Smart Device Agent Base is securely upgraded to a full Smart Device Agent from JAMc, which will then allow printed pages to be accounted for in a Managed Print Services (MPS) account. The driver-only web packs downloaded from hp.com for the printer and installed through the Add Printer wizard do not install this service.
To uninstall the service, open the Control Panel, select Programs or Programs and Features, and then select Add/Remove Programs or Uninstall a Program to remove the service. The file name is HPSmartDeviceAgentBase.
Printer dimensions
Dimensions for E62655dn, E62665h
Dimension
Printer fully closed
Printer fully opened
Height
640 mm
865 mm
Depth
558 mm
805 mm
Width
512 mm
1,030 mm
Weight (with toner cartridge)
33.2 kg
Dimensions for E62665hs, E62665z, E62675z
Dimension
Height
1,234 mm
1,500 mm
Depth
658 mm
890 mm
Width
661 mm
1,030 mm
64.3 kg
Dimensions for the 1 x 550-sheet paper feeder
Dimension
Accessory fully closed
Accessory fully opened
Height
148 mm
148 mm
Depth
558 mm
869 mm
Width
512 mm
617 mm
6.8 kg
Dimensions for the 1 x 550-sheet feeder with printer stand
Dimension
Height
478 mm
478 mm
Depth
658 mm
1,050 mm
Width
660 mm
980 mm
19.28 kg
Dimensions for the 3 x 550-sheet paper feeder with stand
Dimension
Height
450 mm
450 mm
Depth
657 mm
984 mm
Width
657 mm
992 mm
22.7 kg
Dimensions for the 1 x 550-sheet feeder and 2,100-sheet HCI with stand
Dimension
Height
478 mm
478 mm
Depth
658 mm
975 mm
Width
660 mm
980 mm
24.5 kg
Dimensions for the envelope feeder cassette
Dimension
Height
148 mm
148 mm
Depth
558 mm
869 mm
Width
512 mm
617 mm
6.9 kg
Power consumption, electrical specifications, and acoustic emissions
Power consumption
Power consumption (average, in watts)1
Printing
Ready
Sleep
Off
740 W
29 W
3.3 W
Less than 0.1 W
1Values subject to change.
Electrical specifications
Power requirements are based on the country/region where the printer is sold. Do not convert operating voltages. This will damage the printer and void the printer warranty.
Power and rated current specifications
Specification
110-volt models
220-volt models
Power requirements1
100 to 127 volts (± 10%)
  • Minimum: 90 V
  • Maximum: 140 V
50/60 Hz (± 3 Hz)
  • Minimum: 47 Hz
  • Maximum: 63 Hz
220 to 240 volts (± 10%)
  • Minimum: 198 V
  • Maximum: 264 V
50/60 Hz (± 3 Hz)
  • Minimum: 47 Hz
  • Maximum: 63 Hz
Rated current
12 amps
6 amps
1Power reported is highest value measured for all printer models using standard voltages.
Acoustic emissions
Ensure the printer is installed in an area where the printer sound level will not disturb workers.
Acoustic emissions are declared per ISO 9296
Model E62655dn - Acoustic declared values
Printer status
Sound power level
Sound pressure level
Ready
Inaudible
Inaudible
Printing
6.9 B(A)
55 dB(A)
Scanning
7.2 B(A)
58 dB(A)
Copying
7.4 B(A)
59 dB(A)
Model E62665h, E62665z, E62665hs - Acoustic declared values
Printer status
Sound power level
Ready
Inaudible
Inaudible
Printing
7.0 B(A)
56 dB(A)
Scanning
7.2 B(A)
58 dB(A)
Copying
7.4 B(A)
60 dB(A)
Model E62675zh - Acoustic declared values
Printer status
Sound power level
Ready
Inaudible
Inaudible
Printing
7.1 B(A)
57 dB(A)
Scanning
7.2 B(A)
58 dB(A)
Copying
7.5 B(A)
60 dB(A)
Operating environment range
Environment
Recommended
Allowed
Temperature
17° to 25°C
10° to 32.5°C
Relative humidity
30% to 70% relative humidity (RH)
10% to 80% RH
