HP Notebook - 15s-du0005tx Product Specifications
6MU72PA
Intel® Core™ i5 8265U (1.6 GHz base frequency, up to 3.9 GHz with Intel® Turbo Boost Technology, 6 MB cache, 4 cores)
Intel® Integrated SoC
4 GB DDR4-2400 SDRAM (1 x 4 GB)
  • 1 TB 5400 rpm SATA
  • 128 GB M.2 SSD
15.6" diagonal FHD IPS anti-glare WLED-backlit (1920 x 1080)
Realtek 802.11 a/b/g/n/ac (1x1) and Bluetooth® 4.2 Combo
1 USB 3.1 Gen 1 Type-C™ (Data Transfer Only, 5 Gb/s signaling rate); 2 USB 3.1 Gen 1 Type-A (Data Transfer Only); 1 RJ-45; 1 AC smart pin; 1 HDMI; 1 headphone/microphone combo
35.85 x 24.2 x 1.99 cm
Starting at 1.74 kg
65 W AC power adapter
3-cell, 41 Wh Li-ion
HP TrueVision HD Camera with integrated dual array digital microphone
Dual speakers
HP Audio Switch; HP Documentation; HP ePrint; HP JumpStart; HP Support Assistant
