HP Engage One Prime Specifications
Product image
HP Engage One Prime
Processors
Feature
Processors
Qualcomm Snapdragon APQ8053, 64-bit ARM Cortex-A53 Octa-core, 1.8 GHz, 2 GB memory
Qualcomm Snapdragon APQ8053 Lite and 8053 PRO
Multicore is designed to improve performance of certain software products. Not all customers or software applications necessarily benefit from use of this technology. Performance and clock frequency vary depending on application workload and hardware and software configurations. Intel numbering is not a measurement of higher performance.
Feature
Main display (integrated)
General
35.56 cm (14 in) diagonal Wide-aspect display, Full HD, Anti-Glare, 220 cd/m², 100% sRGB, WLED-backlit
Touch technology
Projected capacitive touchscreen
Resolution
1920 (H) x 1080 (V)
Aspect ratio
16:9
Maximum color
262 K
Brightness (typical)
220 nits (LCM)
Contrast ratio (typical)
700:1
Pixel pitch
161.0 um x 161.0 um
Viewing angle
Horizontal 85°, vertical 85°
Response rate (typical On/Off)
30 ms
Backlight
LED
Operating temperature range
0 to 50°C
Customer facing display (optional)
General
13.97 cm (5.5 in) diagonal Wide-aspect display, Full HD, Anti-Glare AMOLED panel
Resolution
1920 (H) x 1080 (V)
Aspect ratio
16:9
Maximum color
16.7 M
420 nits
Contrast ratio (minimum)
100 K: 1
Pixel pitch
63.25 um x 63.25 um
Viewing angle
All view
1 ms
Backlight
LED
0 to 50°C
Specifications might vary.
Memory/storage
Feature
Memory
2 GB (LPDDR3)/16 GB (eMMC)
Audio
Feature
Speaker
Internal speaker
Yes, 1 W embedded, codec
Microphone
(1) Integrated
Ports/slots
Feature
Ports (rear)
(2) USB Type-C ports (Support power and data)
If either of the USB-C ports becomes PD power sink (15V/3A), the other port can be PD source (5 V/0.9 A, 5 V/3 A, 9 V/3 A)
(2) USB 2.0 ports (5V/0.5A)
Slots
(1) Security cable slot
Networking
Feature
WLAN (optional)
IEEE 802.11a/b/g/n/ac (2x2) Wi-Fi and Bluetooth 4.2 combo
Frequency band
2.4 GHz/5 GHz
NFC (integrated)
Integrated NFC solution supporting P2P and R/W working modes for Type A, B, and F signals with NFC forum standard tags of type 1, type 2, type 3, and type 4
Wireless access point and Internet service required and not included. Availability of public wireless access points limited. The specifications for the 802.11ac WLAN are draft specifications and are not final. If the final specifications differ from the draft specifications, it might affect the ability of the workstation to communicate with other 802.11ac WLAN devices.
Power
Feature
Power supply
45 W
87.8% efficient at 15 V, active PFC
Operating voltage range
90 to 265 VAC
Rated voltage range
100 to 240 VAC
Rated line frequency
50 to 60 Hz
Operating line frequency range
47 to 63 Hz
Rated input current
< 2.2 A/120 W
< 1.4 A/45 W
Power cord length
(2) I/O Base cable options
(1) 39.37 in (1 m) – for 120 W power adaptor for HP Engage One Prime I/O Hub when it is attached
(1) 39.37 in (1 m) – for 45 W power adaptor when HP Engage One Prime I/O Hub is detached
Physical specifications
Feature
Dimensions (W X D X H)
Base unit
334.01 (W) x 260.09 (L) x 127.0 (H) mm (13.15 x 10.24 x 5 in)
Packaging unit
406.90 (W) x 325.12 (L) x 219.96 (H) mm (16.02 x 12.80 x 8.66 in)
3.57 kg (7.87 lb)
Software/OS
Feature
Software/Operating system
Android 8.1 "Oreo"
In accordance with Microsoft support policy, this product does not support Windows 8 or Windows 7. HP does not support the Windows 8 or Windows 7 operating system on products configured with Intel 7th generation or later processors, or provide any Windows 8 or Windows 7 drivers.
Not all features are available in all editions or versions of Windows. Systems might require upgraded and/or separately purchased hardware, drivers, and/or software to take full advantage of Windows functionality. Windows 10 automatic updates are always enabled. ISP fees might apply and additional requirements might apply over time for updates.
Other features
Feature
Front camera
Integrated front camera (5M, FF)
Barcode reader/Back camera
Integrated back camera (5M, FF) with flash LED
Magnetic stripe reader
Integrated MSR reader, triple-track head, ISO 7811/7812/7813 Compliant, encryption capable
Internet access and MSR authorization software required and software is sold separately.
Environmental and certifications
Feature
Temperature
Operating
0 to 35°C (32 to 95°F)
Non-operating
-30 to 65°C (-22 to 149°F)
Relative humidity
Operating
10 to 95%
Altitude (unpressurized)
Operating
3,048 m (0 to 10,000 ft)
Non-operating
9,144 m (0 to 30,000 ft)
Eco-label certifications and declarations
US ENERGY STAR
EPEAT Silver (registration varies by country/region)
