    Fix HP Printer issue on macOS
HP LaserJet Managed MFP E72425, E72430, E77422, E77428, E78223, E78228 - 13.B2.A1, 13.B2.D1, 13.A8 jam error in tray 1 (multipurpose tray)
Use the following procedure to clear paper jams in tray 1 (multipurpose tray). When a jam occurs, the control panel displays a message and an animation that assists in clearing the jam.
  • 13.B2.A1 Jam in right door
  • 13.B2.D1 Jam in tray 1
  • 13.A8.A1 Jam in tray 1
  • 13.A8.D1 Jam in tray 1
In addition to the instructions provided in this document, you can view the following video of how to clear a paper jam in Tray 1:
  1. Gently remove the jammed paper from tray 1.
    Figure : Remove jammed paper from tray 1
  2. Open and then close the front door to resume printing.
