HP LaserJet Managed MFP E72425, E72430, E77422, E77428 - Clear paper jams in the document feeder (31.13.yz)
The following information describes how to clear paper jams in the document feeder. When a jam occurs, the control panel displays an animation that assists in clearing the jam.
  1. Open the document-feeder cover.
    Figure : Open the document-feeder cover
  2. Remove any jammed paper. To remove the jammed paper easily, turn the green wheel.
  3. Close the document-feeder cover.
    Figure : Close the document-feeder cover
To avoid jams, make sure the guides in the document-feeder input tray are adjusted against the document, without bending the document. To copy narrow documents, use the flatbed scanner. Remove all staples and paper clips from original documents.
Original documents that are printed on heavy, glossy paper can jam more frequently than originals that are printed on plain paper.
