    We are upgrading our website
    Microsoft Support for Windows 7 ended on Jan 14, 2020
    - HP recommends that you begin the process of upgrading to Windows 10 if your computer has been tested by HP. For more information, click here.
    - If your computer is not compatible for upgrade to Windows 10, we can help to find the perfect computer for you. Check our Weekly deals!
HP PrinterOn Enterprise - There was an error in uploading the document when submitting via mobile app
This is caused by the service URL in the PrinterOn web administration cloud not being set to the proper address of the PrinterOn Enterprise solution (the private address).
This Service URL is what the PrinterOn mobile application uses to submit the job to the PrinterOn Enterprise solution.
By default the PrinterOn Enterprise solution uses 127.0.0.1 therefore this needs to be changed using the steps below.
  1. Log into the PrinterOn web administration at www.printeron.com/administrators
  2. Navigate to the Service Details tab.
  3. Scroll to the bottom of the page and enter the IP or DNS address for the server hosting your PrinterOn software.
  4. Ensure you enter /cps after the address.
  5. Save changes.
  6. Log into PrinterOn's Configuration Manager.
  7. Click the Printers tab.
  8. Click the refresh icon next to the “Date last synchronized” text.
  9. Send a new test print to confirm functionality.
Applies to PrinterOn Enterprise 2.5 and later running in Hybrid or Onpremise mode.
