HP PrinterOn Enterprise - Does the PrinterOn Android mobile app require PrinterOn Print Service Plugin in order to work?
The PrinterOn mobile application for Android is not dependent on the PrinterOn Print Service plugin, and can work independently.
Having the PrinterOn service plugin allows the user to print without opening up the PrinterOn mobile application.
The PrinterOn Print Service Plugin cannot communicate with a PrinterOn Enterprise printer unless the PrinterOn mobile application has been installed.
