    Fix Windows 10 Update Issues
HP LaserJet Managed MFP E82540-E82560, HP Color LaserJet Managed MFP E87640-E87660 - Printer views (du models)
Locate key features on the printer and the control panel.
Printer front view
Locate features on the front of the printer.
Printer front view
    Figure : Printer front view
  1. Automatic document feeder cover, for access for clearing jams
  2. Automatic document feeder input tray
  3. Automatic document feeder output tray
  4. Control panel with color touchscreen display (tilts up for easier viewing)
  5. Output bin
  6. On/off button
  7. Right door, for access for clearing jams
  8. Tray 1
  9. Front door, for access to the toner cartridges
  10. Power connection
  11. Tray 2
  12. Tray 3
  13. Hardware integration pocket (HIP), for connecting accessory and third-party devices
  14. Easy-access USB portInsert a USB flash drive for printing or scanning without a computer or to update the printer firmware.An administrator must enable this port before use.
Printer back view
Locate features on the back of the printer.
Printer back view
    Figure : Printer back view
  1. Formatter cover
  2. Interface ports
  3. Serial number and product number label
Interface ports
Locate the interface ports on the printer formatter.
Interface ports view
    Figure : Interface ports view
  1. USB host ports for connecting external USB devices (these ports might be covered)For easy-access USB printing, use the USB port near the control panel.
  2. Slot for a cable-type security lock
  3. Local area network (LAN) Ethernet (RJ-45) network port
  4. Hi-Speed USB 2.0 printing port
Control-panel view
The control panel provides access to the printer features and indicates the current status of the printer.
Tilt the control panel for easier viewing.
The Home screen provides access to the printer features and indicates the current status of the printer.
Return to the Home screen at any time by touching the Home button. Touch the Home button on the left side of the printer control panel, or touch the Home button in the upper-left corner of most screens.
The features that appear on the Home screen can vary, depending on the printer configuration.
Control-panel view
    Figure : Control-panel view
  1. Home button
  2. Reset button
  3. Sign In or Sign Out button
  4. Information button
  5. Help button
  6. Applications area
  7. Copy button
  8. Home-screen page indicator
How to use the touchscreen control panel
Perform the following actions to use the printer touchscreen control panel.
Touchscreen control panel actions
Action
Example
Touch
Touch an item on the screen to select that item or open that menu. Also, when scrolling through menus, briefly touch the screen to stop the scrolling.
Touch the Settings icon to open the Settings app.
Swipe
Touch the screen and then move your finger horizontally to scroll the screen sideways.
Swipe until the Settings app displays.
Scroll
Touch the screen and then move your finger vertically to scroll the screen up and down. When scrolling through menus, briefly touch the screen to stop the scrolling.
Scroll through the Settings app.
