HP Color Laser 178, 179 Printers - First Time Printer Setup
This document is for HP Color Laser MFP 178nw, 178nwg, 179fnw, and 179fwg printers.
To set up a printer for the first time, remove the printer from the box and all packing materials from the printer, load paper into the input tray, connect the power cable, and then download and install the printer software.
If you are looking for the printer software, go to 123.hp.com.
Remove the printer from the box and all tape, stickers, and packing materials from the printer.
  1. Remove the printer from the box, and then remove the tape from outside the printer.
  2. Lift the scanner lid, remove the packing material from the scanner glass, and then close the scanner lid.
    Remove packing material from the scanner bed
  3. Open the toner cartridge access door, and then remove the packing material from inside the printer.
    Removing the packing material from inside the toner cartridge access area.
  4. Recycle the packing materials.
Step 2: Load paper into the input tray
Load plain U.S. letter or A4 paper in the input tray.
  1. Pull out the input tray.
    Pulling out the input tray.
  2. Remove the tape, and then raise the paper cover.
    Opening the paper cover.
  3. To switch between U.S. Letter and A4-size paper or load legal-size paper, extend the input tray by pressing the latch, and then pulling out the front of the tray.
    Extending the input tray.
  4. Turn over the input tray, grasp the lever, and then rotate the lever clockwise for letter or counterclockwise for A4.
    Switching between U.S. Letter and A4-size paper.
  5. Turn the input tray right-side up, and then push in the extended tray until it snaps into place.
  6. Slide out the paper guides as far as possible.
    Sliding the paper width guides to their outermost positions.
  7. Load paper into the tray print side up with the top edge towards the printer. To prevent paper jams, make sure the stack is below the paper fill guide.
    Loading paper.
  8. Slide in the paper guides until they touch the edge of the stack of paper.
    Sliding the paper guides inward.
  9. Close the paper cover, and then push in the input tray.
    Pushing in the input tray.
  10. Pull out the output support.
    Pulling out the output support.
Step 3: Connect the power cord and set your preferences
Plug the printer into an electrical outlet, turn on the printer, and then set your preferences.
  1. Connect the power cord to the rear of the printer, then plug the other end of the power cord into an electrical outlet.
    Connecting the power cord
  2. If the printer does not turn on automatically, press the Power button.
  3. To set your preferences on the printer control panel, select your preferred country/region, and then press OK.
  4. Wait until the printer is idle and silent before you continue.
Step 4: Connect the fax cables (179fnw, 179fwg printers)
If you plan on using the fax feature, use the fax cables that came with your printer to connect to an available landline.
Connect the phone cord to the phone wall jack, and then connect the other end into the LINE jack on the rear of the printer.
If you are using an answering machine, connect the phone cord to the machine, and then connect the other end to the EXT jack.
Connecting the fax cables
For additional information, go to How to Fax.
Step 5: Install the printer software
Your HP printer hardware is now set up, and you can install the printing software. Do not attempt to connect the printer to a computer until instructed to do so during software installation.
Download the latest version of the printing software from 123.hp.com.
