    Windows 11 Upgrade Guide
HP Pavilion x360 14-cd1700ng Product Specifications
5QT66EA
Intel® Core™ i5-8265U (1.6 GHz base frequency, up to 3.9 GHz with Intel® Turbo Boost Technology, 6 MB cache, 4 cores)
  • 1 TB 5400 rpm SATA
  • 128 GB M.2 SSD
35.6 cm (14") diagonal FHD IPS micro-edge WLED-backlit multitouch-enabled edge-to-edge glass (1920 x 1080)
Pointing device
Realtek RTL8821CE 802.11b/g/n/ac (1x1) Wi-Fi® and Bluetooth® 4.2 Combo
1 USB Type-C™ 3.1 Gen 1 (Data transfer only, up to 5Gb/s); 2 USB 3.1 Gen 1 (1 HP Sleep and Charge); 1 HDMI 1.4; 1 headphone/microphone combo
32.35 x 22.42 x 2.05 cm
1.68 kg
65 W AC power adapter
3-cell, 41 Wh Li-ion
Battery life mixed usage
Up to 10 hours and 30 minutes
Video Playback Battery life
Up to 6 hours and 45 minutes
HP 3D DriveGuard; HP Audio Switch; HP CoolSense; HP JumpStart
Pre-installed software
Netflix
