HP Laser MFP 130 Printers - Replacing the Toner Cartridge
This document is for HP Laser MFP 131a, 133pn, 135a, 135ag, 135r, 135w, 135wg, 136a, 136nw, 136w, 137fnw, 137fwg, 138fnw, 138p, 138pn, and 138pnw printers.
Replace the toner cartridge if it is low or empty.
To replace the toner cartridge, open the toner cartridge access door, remove the old toner cartridge, and then install a new one.
  1. Lift the scanner assembly.
    Lifting the scanner assembly
  2. Lift to open the toner access door.
    Lifting to open the toner access door
  3. Grasp the handle on the toner cartridge, and then pull the toner cartridge out to remove it.
    Grasping the toner cartridge, and then removing it
  4. Remove the new toner cartridge from its package, and then discard or recycle the packing materials.
    Removing the new toner cartridge from its package
  5. Grasp both sides of the toner cartridge, and then distribute the toner by gently rocking the toner cartridge back and forth.
    Grasping the toner cartridge, and then gently rocking the toner cartridge back and forth
  6. Align the new toner cartridge with the tracks inside the printer, and then push the toner cartridge until it is firmly seated.
    Installing the toner cartridge
  7. Close the toner access door.
    Closing the toner access door
  8. Close the scanner assembly.
    Closing the scanner assembly
Review the list of frequently asked questions about replacing toner cartridges.
