    We are upgrading our website
    Fix Windows 10 Update Issues
HP Gaming Pavilion - 15-cx0104ur Product Specifications
5GZ66EA
Intel® Core™ i7-8750H (2.2 GHz base frequency, up to 4.1 GHz with Intel® Turbo Boost Technology, 9 MB cache, 6 cores)
Intel® HM370
16 GB DDR4-2666 SDRAM (2 x 8 GB)
Video graphics
NVIDIA® GeForce® GTX 1050 (4 GB GDDR5 dedicated)
1 TB 7200 rpm SATA
39.6 cm (15.6") diagonal FHD IPS anti-glare micro-edge WLED-backlit (1920 x 1080)
Pointing device
802.11b/g/n/ac (2x2) Wi-Fi® and Bluetooth® 4.2 combo
1 USB 3.1 Type-C™ Gen 1 (Data transfer only, up to 5 Gb/s); 3 USB 3.1 Gen 1 (1 HP Sleep and Charge); 1 HDMI 2.0; 1 RJ-45; 1 headphone/microphone combo
36.5 x 25.65 x 2.54 cm
2.4 kg
135 W AC power adapter
3-cell, 52.5 Wh Li-ion
Battery life mixed usage
Up to 10 hours and 15 minutes
Video Playback Battery life
Up to 9 hours and 15 minutes
FreeDOS 1.2
