5VQ96PA
HP Pavilion 15-dp0001tx
Intel® Core™ i7-8750H (2.2 GHz base frequency, up to 4.1 GHz with Intel® Turbo Boost Technology, 9 MB cache, 6 cores)
15.6" diagonal FHD IPS anti-glare WLED-backlit (1920 x 1080)
802.11a/b/g/n/ac (2x2) Wi-Fi® and Bluetooth® 4.2 combo
2 USB 3.1 Gen 1 (Data transfer only); 1 USB 2.0; 1 HDMI; 1 RJ-45; 1 headphone/microphone combo
38.24 x 25.25 x 2.45 cm
Starting at 2.2 kg
200 W AC power adapter
4-cell, 63 Wh Li-ion polymer
- ${title}
- ${title}
- ${title}
- ${title}
HP Pavilion 15-dp0001tx Product Specifications
HP 3D DriveGuard; HP Audio Switch; HP Documentation; HP ePrint; HP e-Service; HP JumpStart; HP Support Assistant; HP Connection Optimizer; HP Command Center; HP PC Hardware Diagnostics Windows
Pre-installed software
iQiyi
Additional support options
- ${title}
- ${title}
- ${title}
Country/Region:
Thailand
- ${title}
hp-hero-support-search
- ${title}
