HP Pavilion x360 14-cd1021tu Product Specifications
5HW04PA
Intel® Core™ i3-8145U (2.1 GHz base frequency, up to 3.9 GHz with Intel® Turbo Boost Technology, 4 MB cache, 2 cores)
4 GB DDR4-2400 SDRAM (1 x 4 GB)
Video graphics
Intel® UHD Graphics 620
  • 1 TB 5400 rpm SATA
14" diagonal FHD IPS micro-edge WLED-backlit multitouch-enabled edge-to-edge glass (1920 x 1080)
Pointing device
Intel® 802.11a/b/g/n/ac (2x2) Wi-Fi® and Bluetooth® 4.2 Combo
1 USB Type-C™ 3.1 Gen 1 (Data transfer only, up to 5Gb/s); 2 USB 3.1 Gen 1 (1 HP Sleep and Charge); 1 HDMI 1.4; 1 headphone/microphone combo
32.35 x 22.42 x 1.97 cm
Starting at 1.59 kg
45 W AC power adapter
3-cell, 41 Wh Li-ion prismatic
HP Documentation; HP CoolSense; HP Support Assistant; HP JumpStart; HP Connection Optimizer; HP 3D DriveGuard; HP Audio Switch
