    Fix Windows 10 Update Issues
HP Notebook 15-da1002tu Product Specifications
5KF70PA
Intel® Core™ i5-8265U (1.6 GHz base frequency, up to 3.9 GHz with Intel® Turbo Boost Technology, 6 MB cache, 4 cores)
Video graphics
Intel® UHD Graphics 620
1 TB 5400 rpm SATA
Optical drive
DVD-Writer
15.6" diagonal FHD SVA anti-glare micro-edge WLED-backlit (1920 x 1080)
Pointing device
Intel® 802.11a/b/g/n/ac (1x1) Wi-Fi® and Bluetooth® 4.2 Combo
2 USB 3.1 Gen 1 (Data transfer only); 1 USB 2.0; 1 HDMI 1.4b; 1 RJ-45; 1 headphone/microphone combo
37.6 x 24.6 x 2.25 cm
Starting at 1.77 kg
45 W AC power adapter
3-cell, 41 Wh Li-ion prismatic
HP TrueVision HD Camera with integrated digital microphone
Dual speakers
HP Audio Switch; HP JumpStart; HP Documentation; HP ePrint; HP Support Assistant
