    Coronavirus (COVID-19) Impact
    We are experiencing longer than expected wait times to reach an agent. Please use the resources here on our HP Support website to answer your questions and troubleshoot any issues you may be experiencing.  Try our Virtual Agent and Diagnostic Tools for faster service.
    Are you working from home?
Product Specifications for the HP LaserJet Pro MFP M30a Printer (Y5S50A)
Product naming
Model name
Y5S50A
What's included and accessories
What's in the box
Preinstalled HP Original Introductory Black LaserJet Toner Cartridge (~1400 pages); Getting Started Guide; Setup Poster; Support flyer; Warranty guide; Power cord; USB cable (AP only)
Connectivity
Ports
Hi-Speed USB 2.0 port
Wireless capability
No
Copy
Copier settings
Number of Copies; Lighter/Darker; Optimize; Paper
Maximum number of copies
Up to 99 copies
Copy reduce / enlarge settings
25 to 400%
Copy speed (black, normal)
Up to 20 cpm
Copy resolution
600 x 400 dpi
Environmental
Acoustic power emissions (active, printing)
6.6 B(A)
Recommended operating humidity range
30 to 70% RH
Non-Operating Humidity Range
10 to 90% RH
Recommended operating temperature range (Celsius)
17.5 to 25ºC
Storage temperature range (Celsius)
-20 to 60ºC
Environmental specifications
Mercury-free
Memory
Memory
32 MB
Maximum Memory
32 MB
Mobile printing capability
Mobile printing services
USB
Paper handling
Input capacity
Up to 150 sheets (For China) UP to 80 sheets (For India)
Output capacity
Up to 100 sheets
Media sizes supported (metric)
A4; A5; A6; envelopes (C5, DL); custom
Media sizes, custom (metric)
105 x 148 to 216 to 297 mm
Media types
Plain paper, envelope, postcard, Label
Media weight supported (metric)
65 to 120 g/m²
Physical dimensions
Maximum dimensions (W x D x H, metric)
360 x 427 x 347 mm
Weight (metric)
5.4 kg
Power
Energy savings feature technology
HP Auto-on/Auto-off Technology
Power requirements are based on the country/region where the printer is sold. Do not convert operating voltages. This will damage the printer and void the product warranty.
Power supply
110V - 127V nominal @ +/-10% (min 99V, max 140V), 50 - 60Hz nominal +/- 3Hz (min 47Hz, max 63Hz), 220V - 240V nominal @ +/-10% (min 198V, Max 264V), 50 - 60Hz nominal +/- 3Hz (min 47Hz, max 63Hz)
Print cartridges
Number of print cartridges
1 Black
Replacement cartridges
HP 47A Original Black (CH/IN); LaserJet Toner Cartridge CF247A (CH/IN)
Replacement cartridges footnote
Declared yield value in accordance with ISO/IEC 19752 and continuous printing. Actual yields vary considerably based on images printed and other factors. For details see http://www.hp.com/go/learnaboutsupplies
SureSupply note
HP SureSupply alerts you when your print cartridge is running low and helps you purchase online or locally through HP or a participating retailer. Only available with Original HP supplies; Internet access required. To learn more, visit http://www.hp.com/go/SureSupply
Printing specifications
Print technology
Laser
Print resolution (best)
Up to 600 x 600 dpi
Maximum print area (metric)
216 x 297 mm
Monthly duty cycle
Up to 8000 pages
Print languages
PCLmS; URF; PWG
Printer smart software features
HP Auto-On/Auto-Off
Regulatory specifications
Regulatory model number
SHNGC-1701-00
Energy efficiency
CECP
Safety
IEC 60950-1:2005 +A1:2009+A2:2013/EN60950-1:2006 +A11:2009 +A1:2010+A12:2011+A2:2013; IEC 60825-1:2014 / EN 60825-1:2014 (Class 1 Laser/LED Product); IEC 62479:2010 / EN 62479:2010; IEC 62471:2006/ EN62471:2008; GB4943-2011
Electromagnetic compatibility
CISPR 22:2008 & CISPR 32: 2012/ EN 55032:2012 - Class B, EN 61000-3-2: 2014, EN 61000-3-3: 2013, EN 55024: 2010, FCC Title 47 CFR, Part 15 Class B / ICES-003, Issue 6, GB9254-2008, GB17625.1-2012
Scan
Scanner advanced features
No
Scan technology
CIS
Scan resolution, hardware
Up to 600 ppi
Levels of grayscale
256
Bit depth
24 bit
Maximum flatbed scan size (metric)
216 to 297 mm
Twain version
Version 2.1 (Windows 7 or higher)
Security
Security management
Password-protected network embedded Web server
System requirements
Minimum system requirements for Windows
Windows® 10, 8, 7: 32-bit or 64-bit, 2 GB available hard disk space, CD-ROM/DVD drive or Internet connection, USB port, Internet Explorer.
Minimum System Requirements for Macintosh
Apple® macOS Sierra (v10.12) macOS High Sierra (v10.13) macOS Mojave (v10.14); 1.5 GB HD; Internet required; USB
Compatible Network Operating Systems
Windows® 10, 8, 7: 32-bit or 64-bit, 2 GB available hard disk space, CD-ROM/DVD drive or Internet connection, USB port, Internet Explorer. Apple®OS X EI Capitan (v10.11) macOS Sierra (v10.12) macOS High Sierra, (v10.13); 1.5 GB HD; Internet required; USB Linux (For more information, see https://developers.hp.com/hp-linux-imaging-and-printing)
Operating system (supported note)
Not supporting Windows® XP (64-bit) and Windows Vista® (64-bit). Not all "Compatible Operating Systems" are supported with INBOX software; Full solution software available only for Windows 7 and newer; For Windows Server 2008 R2 64-bit, 2012 64-bit, 2012 R2 64-bit, 2016 64-bit only print driver is installed. Windows RT OS for Tablets (32 & 64-bit) uses a simplified HP print driver built into the RT OS; Linux systems use in-OS HPLIP software.
1 Year Limited Warranty (Return to HP/Dealer - Standard Bench Repair)
