    Fix Windows 10 Update Issues
OMEN by HP - 15-dc0088nr Product Specifications
4WW41UA
Intel® Core™ i7-8750H (2.2 GHz base frequency, up to 4.1 GHz with Intel® Turbo Boost Technology, 9 MB cache, 6 cores)
Video graphics
  • NVIDIA® GeForce® GTX 1050 Ti (4 GB GDDR5 dedicated)
  • Discrete
  • 256 GB PCIe® NVMe™ M.2 SSD
  • [18,19]
15.6" diagonal FHD IPS BrightView micro-edge WLED-backlit (1920 x 1080)
802.11b/g/n/ac (2x2) Wi-Fi® and Bluetooth® 4.2 combo
1 HDMI 2.0; 1 headphone/microphone combo; 1 microphone-in; 1 Mini DisplayPort™; 1 RJ-45; 1 USB 3.1 Type-C™ (Data Transfer up to 5 Gb/s, DP1.2, HP Sleep and Charge); 3 USB 3.1 Gen 1 (1 HP Sleep and Charge)
36 x 26.3 x 2.5 cm
2.36 kg
150 W AC power adapter
4-cell, 70 Wh Li-ion
Battery life mixed usage
Up to 13 hours
Video Playback Battery life
Up to 8 hours and 15 minutes
Bang & Olufsen, dual speakers, HP Audio Boost, DTS Headphone:X™ support
HP Audio Switch; HP ePrint; HP JumpStart; HP Recovery Manager; HP Support Assistant; HP Connection Optimizer
Pre-installed software
Netflix
