HP 240 G7 Notebook PC Specifications
Product image
Feature
Preinstalled
Windows 10 Pro 64-bit
Windows 10 Pro 64-bit (National Academic only)
Windows 10 Home 64-bit
Windows 10 Home Single Language 64-bit
Not all features are available in all editions or versions of Windows. Systems might require upgraded and/or separately purchased hardware, drivers, software, or BIOS update to take full advantage of Windows functionality. Windows 10 automatic updates are always enabled. ISP fees might apply and additional requirements might apply over time for updates.
FreeDOS 1.2
In accordance with Microsoft support policy, this product does not support Windows 8 or Windows 7. HP does not support the Windows 8 or Windows 7 operating system on products configured with Intel 7th generation or later processors, or provide any Windows 8 or Windows 7 drivers.
Processors
Specification
Intel Core i7-8550U
1.8 GHz (up to 4.0 GHz) with Intel Turbo Boost technology
8 MB cache
4 cores
Intel UHD Graphics 620
Intel Core i5-8250U
1.6 GHz (up to 3.4 GHz) with Intel Turbo Boost technology
6 MB cache
4 cores
Intel Core i3-7020U
2.3 GHz
3 MB cache
2 cores
Intel HD Graphics 620
Integrated with processor
Multicore is designed to improve performance of certain software products. Not all customers or software applications necessarily benefit from use of this technology. Performance and clock frequency vary depending on application workload and hardware and software configurations. Intel numbering is not a measurement of higher performance.
Graphics
Specification
Integrated
Intel UHD graphics 620 (for Core i5 and i7)
Intel HD graphics 620 (for Core i3)
High-definition (HD) content is required to view high definition images.
Supported
HD Decode
DirectX 12 and
HDMI 5
Optional discrete graphics
AMD Radeon RX 520 (2 GB GDDR5 dedicated)
Feature
Internal
35.56 cm (14.0 in) diagonal HD SVA eDP anti-glare WLED-backlit slim-flat, 220 cd/m2, 67% sRGB (1366 x 768)
HDMI support
Supports resolutions up to 1920 x 1080 external resolution at 60 Hz
Resolutions are dependent upon monitor capability and resolution and color depth settings.
Memory
Specification
Standard
(2) SODIMM (slots are customer non-accessible/non-upgradeable)
Supports single-channel memory for 8 GB
DDR4 PC4 (transfer rates up to 2400 MT/s)
System runs at 2400 (Intel 7th Gen (KBL) runs at 2133)
Configurations
16 GB DDR4-2400 SDRAM (2 x 8 GB)
12 GB DDR4-2400 SDRAM (1 x 4 GB and 1 x 8 GB)
8 GB DDR4-2400 SDRAM (2 x 4 GB)
4 GB DDR4-2400 SDRAM (1 x 4 GB)
16 GB DDR4-2133 SDRAM (2 x 8 GB)
12 GB DDR4-2133 SDRAM (1 x 4 GB and 1 x 8 GB)
8 GB DDR4-2133 SDRAM (1 x 8 GB)
8 GB DDR4-2133 SDRAM (2 x 4 GB)
4 GB DDR4-2133 SDRAM (1 x 4 GB)
Maximum
Due to the non-industry standard nature of some third-party memory modules, only HP branded memory is recommended to ensure compatibility. If memory speeds are mixed, the system performs at the lower memory speed.
Storage
Feature
Primary storage
1 TB 5400 rpm SATA
500 GB 7200 rpm SATA
500 GB 5400 rpm SATA
Primary M.2 storage
128 GB M.2 SATA-3 TLC Solid State Drive
256 GB M.2 SATA-3 TLC Solid State Drive
256 GB PCIe NVMe M.2 Value Solid State Drive
For storage drives, GB = 1 billion bytes. TB = 1 trillion bytes. Actual formatted capacity is less. Up to 30 GB (for Windows 10) is reserved for system recovery software.
Audio/multimedia
Feature
Audio
(2) Integrated stereo speakers
Camera
HP TrueVision HD Camera (Internet access required)
VGA Webcam (Internet access required)
Sold separately or as an optional feature.
Keyboards/pointing devices/function keys
Feature
Keyboard
Full size textured island-style keyboard
Jet black
Function keys
F1 – Open "How to get help in Windows 10" webpage
F2 – Brightness down
F3 - Brightness up
F4 – Display switching
F5 – Blank
F6 – Mute
F7 – Volume down
F8 – Volume up
F9 – Previous
F10 – Play/Pause
F11 – Next
F12 – Airplane mode
Pointing device
Ports
Specification
Ports
(2) USB 3.1 Gen 1
(1) USB 2.0
(1) HDMI 1.4b (cable sold separately)
(1) RJ-45
(1) AC power
(1) Headphone/microphone combo jack
(1) Multi-format digital media reader
Supports SD, SDHC, and SDXC
Networking/communication
Feature
Wireless
Realtek 802.11ac (2x2) Wi-Fi and Bluetooth 4.2 combo (MU-MIMO supported)
Realtek 802.11b/g/n (1x1) and Bluetooth 4.2 combo
Wireless access point and Internet service required and not included. Availability of public wireless access points limited. The specifications for the 802.11ac WLAN are draft specifications and are not final. If the final specifications differ from the draft specifications, it might affect the ability of the notebook to communicate with other 802.11ac WLAN devices.
Supports Miracast
Ethernet
Integrated 10/100/1000 GbE NIC
Power
Specification
Power supply
HP Smart 65 W External AC power adapter
HP Smart 65 W EM External AC power adapter
HP Smart 45 W External AC power adapter
Availability might vary by country/region.
Primary battery
HP Long Life 3-cell, 41 Wh Li-ion polymer
Windows 10 MM14 battery life varies depending on various factors including product model, configuration, loaded applications, features, use, wireless functionality, and power management settings. The maximum capacity of the battery naturally decreases with time and usage.
Power cord
1.0 m (3.28 ft)
Battery Life
Up to 12 hours 30 minutes
Physical specifications
Specification
Starting at 1.52 kg (3.35 lb)
Weight varies by configuration and components.
Dimensions (W x D x H)
33.50 x 23.4 x 1.98 cm (13.19 x 9.21 x 0.78 in)
Software/security
Specification
Preinstalled software
HP JumpStart
HP Documentation
HP ePrint (requires an Internet connection)
HP Setup Integrated OOBE
HP SSRM
HP Audio Switch
HP Support Assistant (requires Windows and Internet access)
McAfee LiveSafe
Security
Trusted Platform Module (TPM) 2.0
Security lock slot (lock sold separately)
