HP Notebook - 14s-cf0057tx Product Specifications
5DS88PA
Intel® Core™ i5-8250U (1.6 GHz base frequency, up to 3.4 GHz with Intel® Turbo Boost Technology, 6 MB cache, 4 cores)
4 GB DDR4-2400 SDRAM (1 x 4 GB)
Video graphics
AMD Radeon™ 530 Graphics (2 GB GDDR5 dedicated)
  • 1 TB 5400 rpm SATA
14" diagonal FHD IPS BrightView micro-edge WLED-backlit (1920 x 1080)
Keyboard
Full-size island-style keyboard
Pointing device
802.11b/g/n (1x1) Wi-Fi® and Bluetooth® 4.2 combo
1 USB 3.1 Type-C™ Gen 1 (Data Transfer up to 5 Gb/s); 2 USB 3.1 Gen 1 (Data transfer only); 1 HDMI 1.4b. 1 RJ-45; 1 headphone/microphone combo
32.4 x 22.59 x 1.99 cm
Starting at 1.43 kg
65 W AC power adapter
3-cell, 41 Wh Li-ion
HP TrueVision HD Camera with integrated digital microphone
Dual speakers
HP Audio Switch; HP Documentation; HP ePrint; HP JumpStart; HP Recovery Manager; HP Support Assistant; HP Sure Connect
