HP Z2 Tower G4 Workstation Specifications
Product image
Feature
Preinstalled
Windows 10 Pro for Workstations 64
Windows 10 Pro 64 (recommended by HP)
Windows 10 Pro 64 (National Academic License)
Not all features are available in all editions or versions of Windows. Systems might require upgraded and/or separately purchased hardware, drivers, software, or BIOS update to take full advantage of Windows functionality. Windows 10 automatic updates are always enabled. ISP fees might apply and additional requirements might apply over time for updates.
HP Linux Ready
Supported
Red Hat Enterprise Linux (RHEL) Workstation (12-month paper license available, not preinstalled)
HP Workstations can be ordered with a variety of localization options that might vary by platform. Refer to the Linux Hardware Matrix for additional Linux OS information.
Processors
Specification
Intel Xeon processor E-2286G
Up to 4.9 GHz with Intel Turbo Boost Technology (4.0 GHz base frequency)
12 MB cache and 6 cores
Intel UHD Graphics P630
DDR4 memory up to 2666 MT/s data rate
80 W TDP
Intel vPro Technology
Intel Xeon processor E-2278G
Up to 5.0 GHz with Intel Turbo Boost Technology (3.4 GHz base frequency)
16 MB cache and 8 cores
80 W TDP
Intel Xeon processor E-2276G
Up to 4.9 GHz with Intel Turbo Boost Technology (3.8 GHz base frequency)
80 W TDP
Intel Xeon processor E-2274G
8 MB cache and 4 cores
80 W TDP
Intel Xeon processor E-2244G
Up to 4.8 GHz with Intel Turbo Boost Technology (3.8 GHz base frequency)
80 W TDP
Intel Xeon processor E-2236
Up to 4.8 GHz with Intel Turbo Boost Technology (3.4 GHz base frequency)
80 W TDP
Intel Xeon processor E-2226G
Up to 4.7 GHz with Intel Turbo Boost Technology (3.4 GHz base frequency)
80 W TDP
Intel Xeon processor E-2224G
Up to 4.6 GHz with Intel Turbo Boost Technology (3.4 GHz base frequency)
80 W TDP
Intel Xeon E-2176G processor
Up to 4.7 GHz with Intel Turbo Boost Technology (3.7 GHz base frequency)
80 W TDP
Intel Xeon E-2174G processor
Up to 4.7 GHz with Intel Turbo Boost Technology (3.8 GHz base frequency)
71 W TDP
Intel Xeon E-2144G processor
Up to 4.5 GHz with Intel Turbo Boost Technology (3.6 GHz base frequency)
71 W TDP
Intel Xeon E-2136 processor
Up to 4.5 GHz with Intel Turbo Boost Technology (3.3 GHz base frequency)
80 W TDP
Intel Xeon E-2126G processor
80 W TDP
Intel Xeon E-2124G processor
Up to 4.3 GHz with Intel Turbo Boost Technology (3.4 GHz base frequency)
71 W TDP
Intel Xeon E-2104G processor
3.2 GHz base frequency
65 W TDP
Intel Core i9-9900K processor
Up to 5.0 GHz with Intel Turbo Boost Technology (3.6 GHz base frequency)
Intel UHD Graphics 630
95 W TDP
16 GB Intel Optane memory
Intel Core i9-9900 processor
Up to 5.0 GHz with Intel Turbo Boost Technology (3.1 GHz base frequency)
95 W TDP
Intel Core i7-9700K processor
Up to 4.9 GHz with Intel Turbo Boost Technology (3.6 GHz base frequency)
12 MB cache and 8 cores
95 W TDP
Intel Core i7-9700 processor
Up to 4.7 GHz with Intel Turbo Boost Technology (3.0 GHz base frequency)
95 W TDP
Intel Core i5-9600 processor
Up to 4.6 GHz with Intel Turbo Boost Technology (3.1 GHz base frequency)
9 MB cache and 6 cores
95 W TDP
Intel Core i5-9500 processor
Up to 4.4 GHz with Intel Turbo Boost Technology (3.0 GHz base frequency)
95 W TDP
Intel Core i3-9100 processor
Up to 4.2 GHz with Intel Turbo Boost Technology (3.6 GHz base frequency)
95 W TDP
Intel Core i7-8700K processor
95 W TDP
Intel Core i7-8700 processor
Up to 4.6 GHz with Intel Turbo Boost Technology (3.2 GHz base frequency)
65 W TDP
Intel Core i5-8600 processor
Up to 4.2 GHz with Intel Turbo Boost Technology (3.1 GHz base frequency)
65 W TDP
Intel Core i5-8500 processor
Up to 4.0 GHz with Intel Turbo Boost Technology (3.0 GHz base frequency)
65 W TDP
Intel Core i3-8100 processor
3.6 GHz Base frequency
6 MB cache and 4 cores
DDR4 memory up to 2400 MT/s data rate
65 W TDP
Intel Pentium Gold G5400 processor
4 MB cache and 2 cores
Intel UHD Graphics 610
54 W TDP
Intel C246
Multicore is designed to improve performance of certain software products. Not all customers or software applications necessarily benefit from use of this technology. Performance and clock frequency vary depending on application workload and hardware and software configurations. Intel numbering is not a measurement of higher performance.
Intel Optane memory system acceleration does not replace or increase the DRAM in your system.
Some functionality of the vPro technology - such as Intel Active management technology and Intel Virtualization technology require additional 3rd party software in order to run.
Intel Turbo Boost is based on maximum GHz for a single core.
Graphics
Feature
Integrated
Single graphic card supported.
Entry 3D
AMD Radeon Pro WX 3100 4 GB Graphics
NVIDIA Quadro P400 2 GB Graphics
Two graphic cards supported.
NVIDIA Quadro P620 2 GB Graphics
Mid-range 3D
Radeon Pro WX4100 4 GB GFX Graphics
NVIDIA Quadro P2000 5 GB Graphics
NVIDIA Quadro P1000 4 GB Graphics
High-end 3D
Radeon Pro WX7100 8 GB Graphics
NVIDIA Quadro P4000 8 GB Graphics
NVIDIA Quadro P5000 16 GB Graphics
NVIDIA Quadro RTX 4000 8 GB Graphics
NVIDIA Quadro RTX 5000 16 GB Graphics
Requires 500 W PSU, not supported with 250 W PSU.
NVIDIA Quadro RTX6000 24 GB Graphics
Requires 650 W PSU, not supported with 250 W or 500 W PSUs.
Graphics cable adapters
HP DisplayPort to Dual Link DVI Adapter
HP DisplayPort to DVI-D Adapter
HP DisplayPort to VGA Adapter
HP DisplayPort to HDMI Adapter
HP mini-DisplayPort to DP Adapter
HP USB-C to VGA Adapter
HP USB-C to HDMI Adapter
HP USB-C to DP Adapter
Intermixing integrated Intel UHD graphics and discrete graphics cards to drive more than three displays can be enabled using the Computer (F10) Setup Utility. However, HP recommends using only discrete graphics when four or fewer displays are required to be supported.
Integrated Intel UHD graphics P630 is supported on the select Intel Xeon E processors. Intel Xeon E, Intel Core i3 and Intel Pentium processors can support either ECC or non-ECC memory. Intel Core i5/i7 processors only support non-ECC memory.
Memory
Specification
Standard
(4) UDIMM slots supporting dual-channel memory
4 GB, 8 GB, 16, and 32 GB UDIMMs
Supported configurations
8 GB (1 x 8 GB) DDR4-2666 ECC
16 GB (2 x 8 GB) DDR4-2666 ECC
32 GB (4 x 8 GB) DDR4-2666 ECC
32 GB (2 x 16 GB) DDR4-2666 ECC
64 GB (4 x 16 GB) DDR4-2666 ECC
64 GB (2 x 32 GB) DDR4-2666 ECC
128 GB (4 x 32 GB) DDR4-2666 ECC
4 GB (1 x 4 GB) DDR4-2666 non-ECC
8 GB (2 x 4 GB) DDR4-2666 non-ECC
8 GB (1 x 8 GB) DDR4-2666 non-ECC
16 GB (2 x 8 GB) DDR4-2666 non-ECC
32 GB (4 x 8 GB) DDR4-2666 non-ECC
32 GB (2 x 16 GB) DDR4-2666 non-ECC
64 GB (4 x 16 GB) DDR4-2666 non-ECC
64 GB (2 x 32 GB) DDR4-2666 non-ECC
128 GB (4 x 32 GB) DDR4-2666 non-ECC
ECC and non-ECC memory DIMMs cannot be mixed on the same system.
Maximum
Up to 128 GB
Maximum memory capacities assume Windows 64-bit operating systems or Linux. With Windows 32-bit operating systems, memory above 3 GB might not all be available due to system resource requirements.
Two channels of DDR4 memory are supported. To realize full performance, at least one DIMM must be inserted into each channel.
Monitors/displays
Feature
Supported
HP Z Display Z27n G2 27-inch IPS LED Backlit Monitor
HP Z Display Z24n G2 24-inch IPS LED Backlit Monitor
HP Z Display Z24nf G2 23.8-inch IPS Backlit Monitor
HP Z Display Z23n G2 23-inch IPS LED Backlit Monitor
HP Z Display Z22n G2 21.5-inch IPS LED Backlit Monitor
Resolutions are dependent upon monitor capability and resolution and color depth settings.
Storage and drives
Feature
SATA 8.89 cm (3.5 in) Hard Drives
500 GB SATA 6 Gb/s 7200 HDD
1 TB SATA 6 Gb/s 7200 HDD
2 TB SATA 6 Gb/s 7200 HDD
4 TB SATA 6 Gb/s 7200 HDD
6 TB SATA 6 Gb/s 7200 HDD
500 GB SATA 7200 rpm SED SFF HDD
1 TB 7200 RPM SATA 8 GB SSHD Drive
1 TB Enterprise SATA 7200 HDD
SATA SSD
HP 256 GB SATA SSD
HP 512 GB SATA SSD
HP 1 TB SSD
HP 2 TB SATA SSD
HP 256 GB SATA SED Opal2 SSD
HP 240 GB Enterprise SATA SSD
HP 480 GB Enterprise SATA SSD
Storage Acceleration
16 GB Intel Optane memory (sold separately)
PCIe Solid State Drives
PCIe SSDs for HP Workstations
HP Z Turbo Drive G2 256 GB TLC PCIe SSD
HP Z Turbo Drive G2 512 GB TLC PCIe SSD
HP Z Turbo Drive G2 1 TB TLC PCIe SSD
HP Z Turbo Drive G2 2 TB TLC PCIe SSD
HP Z2 Tower G4 Workstation is capable of configuring up to two Z Turbo Drives. By default, the Z Turbo Drive configured is installed in the M.2 storage slot on the system’s motherboard.
Intel 905p Series SSD (Optane SSD)
Intel Optane SSD 905p 280 GB AiC
Intel Optane SSD 905p 480 GB AiC
PCIe card is installed in standard PCIe x4 slot.
Removable storage
HP 9.5 mm Slim DVD Writer
HP 9.5 mm Slim DVD-ROM Drive
HP 9.5 mm Slim BDXL Blu-ray Writer
HDD Frame/carriers
HP DX175 Removable HDD Carrier
HP DX175 Removable HDD Frame/Carrier
Media card reader
HP SD Media Card Reader
For solid state drives or hard drives, GB = 1 billion bytes. TB = 1 trillion bytes. Actual formatted capacity is less. Up to 30 GB is reserved for system recovery software.
Ports/slots
Ports
Front side
(1) Power button
(1) Headphone/microphone combo jack
(1) USB 3.0 Type-A charging data port
(1) USB 3.0 Type-A data port
(1) USB 3.1 Gen 2 Type-C charging data port (optional)
Back I/O ports
(1) Audio Line-In
(1) Audio Line-Out
(2) DisplayPort (DP) 1.2 outputs (from Intel UHD graphics; select models)
(1) Flexible module port output (optional flexible module required)
(2) USB 2.0 ports
(4) USB 3.0 ports
(1) Serial port (optional)
(2) PS/2 (optional)
(1) Parallel port (optional)
(1) RJ-45
(1) DC Input
Internal I/O ports
(1) USB 3.0 port
(2) USB 2.0 ports
Available as 2 separate 2 x6 (3.0 x1, 2.0 x1) and 1 x6 (2.0 x1) header: supports one USB 3.0 Media Card Reader.
Controller card
HP Thunderbolt 3 PCIe 3-port I/O Card
Utilizes Flex IO port connection for flex port.
Rear module options
HP Flex IO module (VGA)
HP Flex IO module (HDMI)
HP Flex IO module (DP)
HP Flex IO module (USB-C)
HP Flex IO module (1 GbE LAN)
(1) PCIe Gen3 x16 slot
(1) PCIe Gen3 x4 slot/x16 connector
(1) PCIe Gen3 x1 slot/x4 connector
(2) M.2 storage (PCIe Gen3 x4)
(1) SD Card Reader (optional)
(1) M.2 WLAN (PCIe Gen3 x1 and Intel CNVi)
All slots are Low Profile.
M.2 storage supports compatible devices at 80 mm.
The PCIe Gen3 x16 slot is meant for HP qualified cards, configured or after market. HP does not provide warranty support for 3rd party cards.
Bays
(2) External 13.3 cm (5.25 in) bays
(2) Internal 8.89 cm (3.5 in) bays
Audio/multimedia
Feature
Integrated audio
Conexant CX20632 5.1 HDA codec
Keyboard/mouse/other devices
Feature
Keyboard
HP USB Business Slim CCID SmartCard Keyboard
HP USB Business Slim Keyboard
HP USB Premium Keyboard
HP Premium Wireless Keyboard
Mouse
HP USB Optical Mouse
HP USB Hardened Mouse
HP USB Premium Mouse
HP Premium Wireless Mouse
Keyboard and mouse combo
HP Wireless Business Slim Keyboard & Mouse
Other devices
HP Workstation Mouse Pad (Japan only)
HP Serial Port Adapter
HP Serial and PS/2 Adapter
HP Internal USB Port Kit
HP eSATA PCI Cable Kit
HP Z2 G4 TWR Front Card Guide Kit
Networking/communication
Feature
Integrated
Intel I219LM PCIe GbE Controller (Intel vPro with Intel AMT 12.0)
Intel X710-DA2 2-Port 10GbE SFP and NIC
HP 10GbE SFP and SR Transceiver
Intel X550-T2 2-Port 10GbE NIC
Intel 9560 802.11a/b/g/n/ac with Bluetooth 5 M.2
If AMT is provisioned, then network teaming with the integrated LAN port is not possible.
Intel I350-T2 2-Port 1GbE NIC
"Gigabit" Ethernet indicates compliance with IEEE standard 802.3ab for Gigabit Ethernet, and does not connote actual operating speed of 1 Gb/sec. For high speed transmission, connection to a Gigabit Ethernet server and network infrastructure is required.
Aquantia AQN-108 1-Port 5GbE NIC
Software/security
Specification
BIOS
HP BIOSphere Gen4 (features vary)
BIOS Update via Network
Master Boot Record Security
Power On Authentication
Secure Erase (methods outlined in the National Institute of Standards and Technology Special Publication 800-88)
Absolute Persistence Module1
Pre-boot Authentication
Communication/connectivity
HP Wireless Wakeup
HP Value Add software
HP Performance Advisor (preinstalled with Windows 10 only)
HP Remote Graphics Software (RGS) 7.x
HP Hotkey Support - CMIT
HP Velocity
HP Sure Start Gen4
HP Sure Run (requires Intel 8th generation processors)
HP Sure Recover (requires Intel 8th generation processors and wired network connection)
Manageability
HP System Software Manager (SSM)
HP Client Catalog
HP BIOS Configuration Utility (BCU)
HP Driver Packs (available for download)
HP Manageability Integration Kit Gen2 (available for download)
Client Security software
Microsoft Defender
HP Client Security Manager Gen4 (requires Windows and Intel 8th generation processors)
HP Security Manager (including Credential Manager, HP Password Manager, HP Spare Key)
HP Device Access Manager
HP Power On Authentication
Security
For Windows 10, Trusted Platform Module (TPM) 2.0 (Infineon SLB9670)
RAID configurations (optional and requires a second hard drive)
Power-on password (via BIOS)
Setup password (via BIOS)
SATA port disablement (via BIOS)
Serial, USB enable/disable (via BIOS)
Integrated hood sensor
Support for chassis padlocks and cable lock devices
HP Sure Click
1Absolute agent is activated when customers activate a purchased subscription. Subscriptions can be purchased for terms ranging multiple years. Service is limited, check with Absolute for availability outside the U.S. The Absolute Recovery Guarantee is a limited warranty. Certain conditions apply. Data Delete is an optional service provided by Absolute Software. If utilized, the Recovery Guarantee is null and void. In order to use the Data Delete service, customers must first sign a Pre-Authorization Agreement and either obtain a PIN or purchase one or more RSA SecurID tokens from Absolute Software.
HP Cloud Recovery download tool (Cloud Recovery Client) is available under Software and Drivers section on the support page.
Power
Power supply
650 W Power supply
90% efficiency
Wide-ranging
Active PFC
500 W Power supply
90% efficiency
Wide-ranging
Active PFC
250 W Power supply
85% efficiency
Wide-ranging
Active PFC
Rated input current
6 A at 100 to 240 V
Operating voltage range
90 to 269 VAC
Operating line frequency range
47 to 66 Hz
Physical specifications
Dimensions (H x W x D)
Minitower orientation
356 x 169 x 435 mm (14.0 x 6.7 x 17.1 in)
Packaging
599 x 499 x 295 mm (23.5 x 19.6 x 11.6 in)
Typical weight
8.2 kg (18.07 lb)
Configured with one 8.89 cm (3.5 in) hard drive, one optical drive, two DIMMs, and one NVIDIA Quadro P1000 graphics card.
Shipping weight
11.4 kg (25.13 lb)
Environmental
Feature
Certifications
ENERGY STAR (energy-saving features available on selected configurations – Windows only)
IT ECO declaration
US Federal Energy Management Program (FEMP)
China Energy Conservation Program (CECP)
Low Halogen
External power supplies, power cords, cables and peripherals are not low halogen. Service parts obtained after purchase might not be low halogen.
Temperature
Operating
5° to 35°C (41° to 95°F)
Non-operating
-40° to 60°C (-40° to 140°F)
Relative humidity
Operating
10% to 85%, non-condensing
Non-operating
10% to 90%, non-condensing
Altitude (unpressurized)
Operating
3,048 m (10,000 ft)
Non-operating
12,192 m (15,000 ft)
