    Windows 11 Upgrade Guide
HP V220 21.5-inch Monitor Specifications
Product image
Figure : HP V220 21.5-inch Monitor
Panel
Specification
Display panel type
TN with LED backlight
Display size (diagonal)
21.5 in
54.61 cm (21.5 in)
Panel active area (W x H)
47.68 x 26.82 cm (18.77 × 10.56 in)
Aspect ratio
16:9
Resolution (native with speed)
1920 x 1080 at 60 Hz (HD)
Viewing angle (typical)
Up to 90° horizontal
Up to 65° vertical
Brightness (typical)
200 cd/m2
Contrast ratio
Static
600:1 (typical)
Response time
5 ms (on/off)
Pixel pitch
0.24825 x 0.24825 mm
Pixels per inch (PPI)
102.46
Panel bit depth
8-bit (6-bit + Hi-FRC)
Default color temperature
sRGB D65
Backlight lamp life
30,000 hours minimum (to half brightness)
Color gamut
72% NTSC
Low blue light modes
Yes
Anti-glare
Yes
Actual performance varies.
User controls
Specification
Monitor control buttons or switches
Menu/OK
Minus ("-")/Information (DVI input)/Auto (VGA input)
Plus ("+")/Viewing Modes
Next Input
Power
User-assignable function buttons
3 (18 options)
Languages
10 (English, Spanish, German, French, Italian, Dutch, Portuguese, Japanese, Simplified Chinese, and Traditional Chinese)
On-Screen Display (OSD) user controls
Brightness, Contrast, Color Control, Input Control, Image Control, Power Control, Menu Control, Management, Language, Information, and Exit
Signal interface/performance
Specification
Native resolution
Preset VESA graphic modes (noninterlaced)/supported resolutions
640 x 480 at 60 Hz
720 x 400 at 70 Hz
800 x 600 at 60 Hz
1024 x 768 at 60 Hz
1280 x 720 at 60 Hz
1280 x 800 at 60 Hz
1280 x 1024 at 60 Hz
1440 x 900 at 60 Hz
1600 x 900 at 60 Hz
1680 x 1050 at 60 Hz
Horizontal scan range
30-80 kHz
Vertical scan range
50-60 Hz
Pixel clock (maximum)
170 MHz
I/O ports/cables
Specification
Video
(1) VGA
(1) DVI
HDCP support for DVI.
Cables included
(1) VGA 1.5 m (4.92 ft)
Ergonomics
Specification
Plug and play
Yes
Tilt range
-5° to +20° vertical
Detachable stand
Yes
VESA mount
100 mm VESA mount
Security lock-ready
Yes
Power
Specification
Power supply
Internal
Input power
100 to 240 VAC at 50/60 Hz
Maximum power
23 W
Typical power
19 W
Sleep power
0.3 W
Power cable length
1.9 m (6.23 ft)
Physical specifications
Specification
Dimensions (W × D × H)
Unpacked with stand
50.50 x 17.55 x 38.10 cm (19.88 x 6.91 x 15.0 in)
Unpacked without stand (head only)
50.50 x 4.55 x 31.01 cm (19.88 x 1.79 x 12.21 in)
Packaged
57.1 x 12.5 x 39.5 cm (22.48 x 4.92 x 15.55 in)
Unpacked
2.89 kg (6.38 lb)
Packed
3.9 kg (8.6 lb)
Head only
2.62 kg (5.78 lb)
What's in the box?
Specification
Monitor and accessories
AC power cable – 1.5 m (4.92 ft)
VGA cable – 1.9 m (6.23 ft)
Documentation
User guide and warranty
Environmental
Specification
Temperature
Operating
5°C to 35°C (41°F to 95°F)
Non-operating
–20°C to 60°C (-4°F to 140°F)
Humidity
Operating
20% to 80% (non-condensing)
Non-operating
5% to 95%
Altitude
Operating
0 to 5,000 m (0 to 16,400 ft)
Non-operating
0 to 12,192 m (0 to 40,000 ft)
Arsenic-free display glass
Yes
White LED backlights
Yes
Mercury-free display backlights
Yes
Low halogen
Yes
External power supplies, power cords, cables and peripherals are not Low halogen. Service parts obtained after purchase might not be Low halogen.
Eco-label certifications & declarations
EPEAT Silver, (registration varies by country/region)
ENERGY STAR
Microsoft WHQL certification (Windows 10, 8, and 7)
Australian-New Zealand MEPS
BIS
BSMI
CB
CCC
CE
CECP
CEL Grade 2
CSA
FCC
GS
KC
KCC
ICES
ISC
ISO 9241-307
PSB
SEPA
TUV-S
Low Blue Light
Vietnam MEPS
VCCI
WEEE
