    Windows 11 Upgrade Guide
HP Z2 Mini G4 Workstation Specifications
Product image
Feature
Preinstalled
Windows 10 Pro for Workstations 64
Windows 10 Pro 64 (recommended by HP)
Windows 10 Pro 64 (National Academic License)
Not all features are available in all editions or versions of Windows. Systems might require upgraded and/or separately purchased hardware, drivers, software, or BIOS update to take full advantage of Windows functionality. Windows 10 automatic updates are always enabled. ISP fees might apply and additional requirements might apply over time for updates.
HP Linux Ready
Supported
Red Hat Enterprise Linux (RHEL) Workstation (12-month paper license available, not preinstalled)
HP Workstations can be ordered with a variety of localization options that might vary by platform. Refer to the Linux Hardware Matrix for additional Linux OS information.
Processors
Z2 Mini G4 Performance base unit
Specification
Intel Xeon E-2286G processor
Up to 4.9 GHz with Intel Turbo Boost Technology (4.0 GHz base frequency)
12 MB cache and 6 cores
Intel UHD Graphics P630
DDR4 memory up to 2666 MT/s data rate
95 W TDP
Intel vPro Technology
Intel Xeon E-2278G processor
Up to 5.0 GHz with Intel Turbo Boost Technology (3.4 GHz base frequency)
16 MB cache and 8 cores
80 W TDP
Intel Xeon E-2276G processor
Up to 4.9 GHz with Intel Turbo Boost Technology (3.8 GHz base frequency)
80 W TDP
Intel Xeon E-2274G processor
8 MB cache and 4 cores
83 W TDP
Intel Xeon E-2244G processor
Up to 4.8 GHz with Intel Turbo Boost Technology (3.8 GHz base frequency)
71 W TDP
Intel Xeon E-2236G processor
Up to 4.8 GHz with Intel Turbo Boost Technology (3.4 GHz base frequency)
80 W TDP
Intel Xeon E-2226G processor
Up to 4.7 GHz with Intel Turbo Boost Technology (3.4 GHz base frequency)
80 W TDP
Intel Xeon E-2224G processor
Up to 4.7 GHz with Intel Turbo Boost Technology (3.5 GHz base frequency)
71 W TDP
Intel Xeon E-2176G processor
Up to 4.7 GHz with Intel Turbo Boost Technology (3.7 GHz base frequency)
80 W TDP
Intel Xeon E-2174G processor
Up to 4.7 GHz with Intel Turbo Boost Technology (3.8 GHz base frequency)
71 W TDP
Intel Xeon E-2144G processor
Up to 4.5 GHz with Intel Turbo Boost Technology (3.6 GHz base frequency)
71 W TDP
Intel Xeon E-2136 processor
Up to 4.5 GHz with Intel Turbo Boost Technology (3.3 GHz base frequency)
80 W TDP
Intel Xeon E-2126G processor
80 W TDP
Intel Xeon E-2124G processor
Up to 4.3 GHz with Intel Turbo Boost Technology (3.4 GHz base frequency)
71 W TDP
Intel Xeon E-2104G processor
3.2 GHz Base frequency
65 W TDP
Intel Core i9-9900K processor
Up to 5.0 GHz with Intel Turbo Boost Technology (3.6 GHz base frequency)
Intel UHD Graphics 630
95 W TDP
Intel Core i9-9900 processor
Up to 5.0 GHz with Intel Turbo Boost Technology (3.1 GHz base frequency)
65 W TDP
Intel Core i9-9700K processor
Up to 4.9 GHz with Intel Turbo Boost Technology (3.6 GHz base frequency)
12 MB cache and 8 cores
95 W TDP
Intel Core i9-9700 processor
Up to 4.7 GHz with Intel Turbo Boost Technology (3.0 GHz base frequency)
95 W TDP
Intel Core i9-9600 processor
Up to 4.6 GHz with Intel Turbo Boost Technology (3.1 GHz base frequency)
9 MB cache and 6 cores
65 W TDP
Intel Core i9-9500 processor
Up to 4.4 GHz with Intel Turbo Boost Technology (3.0 GHz base frequency)
95 W TDP
Intel Core i9-9100 processor
Up to 4.2 GHz with Intel Turbo Boost Technology (3.6 GHz base frequency)
6 MB cache and 6 cores
65 W TDP
Intel Core i7-8700 processor
Up to 4.6 GHz with Intel Turbo Boost Technology (3.2 GHz base frequency)
65 W TDP
Intel Core i5-8600 processor
Up to 4.2 GHz with Intel Turbo Boost Technology (3.1 GHz base frequency)
65 W TDP
Intel Core i5-8500 processor
Up to 4.0 GHz with Intel Turbo Boost Technology (3.0 GHz base frequency)
65 W TDP
Intel Core i3-8100 processor
3.6 GHz Base frequency
6 MB cache and 4 cores
DDR4 memory up to 2400 MT/s data rate
65 W TDP
Intel Pentium Gold G5400 processor
4 MB cache and 2 cores
Intel UHD Graphics 610
54 W
Intel Core i5/Core i7 and Xeon with vPro technology capable
Intel Virtualization Technology (Intel VT)
Intel Active Management Technology (iAMT)
For Windows operating system only.
Future virtual appliances applications dependent on third-party software and compatibility to be determined.
Intel PCH C246
Z2 Mini G4 Entry base unit
Specification
65 W TDP
65 W TDP
65 W TDP
65 W TDP
65 W TDP
54 W
Intel PCH C246
Multicore is designed to improve performance of certain software products. Not all customers or software applications necessarily benefit from use of this technology. Performance and clock frequency vary depending on application workload and hardware and software configurations. Intel numbering is not a measurement of higher performance.
Intel Turbo Boost is based on maximum GHz for a single core.
Graphics
Feature
Integrated
Single graphic card supported.
Discrete
NVIDIA Quadro P600 4GB Graphics
NVIDIA Quadro P1000 4GB Graphics
AMD Radeon Pro WX 3200 4GB Graphics
AMD Radeon Pro WX 4150 4GB Graphics
Only offered on Z2 Mini G4 Performance base unit.
Intermixing integrated Intel UHD graphics and discrete graphics cards to drive more than three displays can be enabled using the Computer (F10) Setup Utility. However, HP recommends using only discrete graphics when four or fewer displays are required to be supported. Six-display solution is achieved using a combination of Intel UHD graphics and discrete graphics and is ONLY supported on Windows 10.
Graphics cable adapters
HP DisplayPort to HDMI Adapter
HP DisplayPort to Dual Link DVI Adapter
HP DisplayPort to DVI-D Adapter
HP DisplayPort to VGA Adapter
HP USB-C to VGA Adapter
HP USB-C to HDMI Adapter
HP USB-C to DP Adapter
Memory
Specification
Standard
(2) SODIMM slots supporting dual-channel memory
64 GB DDR4 ECC/non-ECC (transfer rates up to 2666 MT/s)
4 GB, 8 GB, 16 GB, and 32 GB SODIMMs
Supported configurations
4 GB, 8 GB, and 16 GB non-ECC unbuffered SODIMMs
HP 4 GB (1 x 4 GB) DDR4-2666 non-ECC SODIMM
HP 8 GB (2 x 4 GB) DDR4-2666 non-ECC SODIMM
HP 8 GB (1 x 8 GB) DDR4-2666 non-ECC SODIMM
HP 16 GB (2 x 8 GB) DDR4-2666 non-ECC SODIMM
HP 32 GB (2 x 16 GB) DDR4-2666 non-ECC SODIMM
HP 64 GB (2 x 32 GB) DDR4-2666 non-ECC SODIMM
Intel Core i5/i7 processors only support non-ECC memory.
8 GB, 16 GB, and 32 GB ECC unbuffered SODIMMs
HP 8 GB (1 x 8 GB) DDR4-2666 ECC SODIMM
HP 16 GB (2 x 8 GB) DDR4-2666 ECC SODIMM
HP 32 GB (2 x 16 GB) DDR4-2666 ECC SODIMM
HP 64 GB (2 x 32 GB) DDR4-2666 ECC SODIMM
ECC and non-ECC memory DIMMs cannot be mixed on the same system.
Maximum
Up to 64 GB
Maximum memory capacities assume Windows 64-bit operating systems or Linux. With Windows 32-bit operating systems, memory above 3 GB might not all be available due to system resource requirements.
Two channels of DDR4 memory are supported. To realize full performance at least one DIMM must be inserted into each channel.
Monitors/displays
Feature
Supported
HP Z Display Z27n G2 27-inch IPS LED Backlit Monitor
HP Z Display Z24n G2 24-inch IPS LED Backlit Monitor
HP Z Display Z24nf G2 23.8-inch IPS Backlit Monitor
HP Z Display Z23n G2 23-inch IPS LED Backlit Monitor
HP Z Display Z22n G2 21.5-inch IPS LED Backlit Monitor
Resolutions are dependent upon monitor capability and resolution and color depth settings.
Storage and drives
Feature
SATA Hard Drives
HP 500GB 7200 RPM SATA SFF 1st HDD
HP 1TB 7200 RPM SATA SFF 1st HDD
2 TB SATA 5400 rpm SFF HDD
SATA Solid State Drives
HP 256GB SATA Solid State Drive
Storage acceleration
16 GB Intel Optane memory
PCIe Solid State Drives
HP Z Turbo Drive G2 256GB TLC
HP Z Turbo Drive G2 512 GB TLC SSD
HP Z Turbo Drive G2 1 TB TLC SSD
HP Z Turbo Drive G2 2TB SSD
M.2 card heatsink is required for M.2 storage.
Removable storage
HP External Ultra-Slim DVD-RW Drive (optional)
For solid state drives or hard drives, GB = 1 billion bytes. TB = 1 trillion bytes. Actual formatted capacity is less. Up to 30 GB is reserved for system recovery software.
Ports/slots
Ports
Front side
(1) Power button
Side I/O ports
(1) Headphone/microphone combo jack
(1) USB 3.0 Type-A charging data port
(1) USB 3.0 Type-A data port
(1) USB 3.1 Gen 2 Type-C charging data port
Back I/O ports (Entry unit)
(2) DisplayPort (DP 1.2) outputs from Intel UHD graphics
(2) USB 3.0 ports
(1) Serial port (optional)
(1) RJ-45 (LoM)
(1) Flexible module port output (optional flexible module required)
(1) DC Input
Back I/O ports (Performance unit) with discrete graphics
(3) DP 1.2 outputs from discrete graphic module
(2) USB-A 3.0 ports
(1) USB 3.1 Gen 2 Type-C port
(1) RJ-45 (LoM)
(1) DC Input
Back I/O ports (Performance unit) with no discrete graphics
(1) DP 1.2 output from discrete graphic module
(2) USB-A 3.0 ports
(1) RJ-45 (LoM)
(1) DC Input
Rear module options
HP Flex IO module (VGA)
HP Flex IO module (HDMI-iGfx)
HP Flex IO module (DP)
HP Flex IO module (USB-C)
HP Flex IO module (Thunderbolt 3.0)
HP Flex IO module (1 GbE LAN)
HP Serial Port Mini module
(1) M.2 2280 (PCIe SSD)
(1) M.2 2230 (WLAN/BT)
Bays
(1) Internal 6.35 cm (2.5 in) bay (for SATA HDDs & SSDs only)
Audio/multimedia
Feature
Integrated audio
Conexant CX20632 5.1 HD Audio
Keyboard/mouse/other devices
Feature
Keyboard
HP USB Business Slim CCID SmartCard Keyboard
HP USB Business Slim Keyboard
HP USB Premium Keyboard
HP Premium Wireless Keyboard
HP Wireless Business Slim Keyboard & Mouse
Mouse
HP USB Optical Mouse
HP USB Hardened Mouse
HP USB Premium Mouse
HP Premium Wireless Mouse
SpaceMouse Pro USB 3D Input Device
3Dconnexion CADMouse
Other devices
HP Serial Port Adapter
HP Z2 Mini G4 VESA Sleeve
Networking/communication
Feature
Integrated
Intel I219LM PCIe GbE Controller (Intel vPro with Intel AMT 12.0)
If AMT is provisioned, then network teaming with the integrated LAN port is not possible.
"Gigabit" Ethernet indicates compliance with IEEE standard 802.3ab for Gigabit Ethernet, and does not connote actual operating speed of 1 Gb/sec. For high speed transmission, connection to a Gigabit Ethernet server and network infrastructure is required.
Supported
Intel 9560 Wireless LAN (802.11ac) and Bluetooth 5 Module
Software/security
Specification
BIOS
HP BIOSphere Gen4 (features vary)
BIOS Update via Network
Master Boot Record Security
Power On Authentication
Secure Erase (methods outlined in the National Institute of Standards and Technology Special Publication 800-88)
Absolute Persistence Module1
Pre-boot Authentication
Communication/connectivity
HP Wireless Wakeup
HP Value Add software
HP Performance Advisor (preinstalled with Windows 10 only)
HP Remote Graphics Software (RGS)
HP PC Hardware Diagnostics UEFI (Windows OS only)
HP Hotkey Support - CMIT
HP Sure Click
HP Sure Start Gen4
HP Sure Run (requires Intel 8th generation processors)
HP Sure Recover (requires Intel 8th generation processors and wired network connection)
Manageability
HP System Software Manager (SSM)
HP Client Catalog
HP BIOS Configuration Utility (BCU)
HP Driver Packs (available for download)
HP Manageability Integration Kit Gen2 (available for download)
Client Security software
Microsoft Defender
HP Client Security Manager Gen4 (requires Windows and Intel 8th generation processors)
HP Security Manager (including Credential Manager, HP Password Manager, HP Spare Key)
HP Device Access Manager
HP Power On Authentication
Security
For Windows 10, Trusted Platform Module (TPM) 2.0 (Infineon SLB9670)
Common Criteria EAL4+ Certified
Power-on password (via BIOS)
Setup password (via BIOS)
SATA port disablement (via BIOS)
Serial, USB enable/disable (via BIOS)
1Absolute agent is activated when customers activate a purchased subscription. Subscriptions can be purchased for terms ranging multiple years. Service is limited, check with Absolute for availability outside the U.S. The Absolute Recovery Guarantee is a limited warranty. Certain conditions apply. Data Delete is an optional service provided by Absolute Software. If utilized, the Recovery Guarantee is null and void. In order to use the Data Delete service, customers must first sign a Pre-Authorization Agreement and either obtain a PIN or purchase one or more RSA SecurID tokens from Absolute Software.
HP Cloud Recovery download tool (Cloud Recovery Client) is available under Software and Drivers section on the support page.
Power
Z2 Mini G4 Entry
135 W Power supply
88% efficiency at 115 Vac
Wide-ranging
Active PFC
1.9 A at 90 Vac
200 W and 230 W Power supply
89% efficiency at 230 Vac
Wide-ranging
Active PFC
2.9 A at 90 Vac (200 W)
3.5 A at 90 Vac (230 W)
Operating voltage range
115 to 230 VAC
Operating line frequency range
47 to 63 Hz
Physical specifications
Dimensions (H x W x D)
58.0 x 215.9 x 215.9 mm (2.28 x 8.5 x 8.5 in)
2.18 kg (4.81 lb)
Configured with one 6.35 cm (2.5 in) hard drive, one PCIe SSD, WLAN module, two DIMMs, and one NVIDIA Quadro graphics card.
Environmental
Feature
Certifications
ENERGY STAR (energy-saving features available on selected configurations – Windows only)
IT ECO declaration
US Federal Energy Management Program (FEMP)
China Energy Conservation Program (CECP)
Low Halogen
External power supplies, power cords, cables and peripherals are not low halogen. Service parts obtained after purchase might not be low halogen.
Temperature
Operating
5° to 35°C (41° to 95°F)
Non-operating
-40° to 60°C (-40° to 140°F)
Relative humidity
Operating
10% to 85%, non-condensing
Non-operating
10% to 90%, non-condensing
Altitude (unpressurized)
Operating
3,048 m (10,000 ft)
Non-operating
12,192 m (15,000 ft)
