    Fix HP Printer issue on macOS
OMEN by HP - 17-an129tx Product Specifications
4LS16PA
Intel® Core™ i7-8750H (2.2 GHz base frequency, up to 4.1 GHz with Intel® Turbo Boost Technology, 9 MB cache, 6 cores)
Intel® HM370
32 GB DDR4-2666 SDRAM (2 x 16 GB)
2 TB 5400 rpm SATA
17.3" diagonal 4K IPS eDP anti-glare WLED-backlit (3840 x 2160)
Keyboard
Full-size 4-zone lighting backlit keyboard with numeric keypad and NKRO
Pointing device
Intel® Wireless-AC 9560 802.11b/g/n/ac (2x2) Wi-Fi® and Bluetooth® 5 Combo
1 Thunderbolt™ 3 (Data Transfer up to 40 Gb/s, DP1.2, HP Sleep and Charge); 3 USB 3.1 Gen 1 (1 HP Sleep and Charge); 1 Mini DisplayPort™; 1 HDMI; 1 RJ-45; 1 headphone/microphone combo; 1 microphone-in
42.3 x 30.4 x 3.3 cm
Starting at 3.73 kg
230 W AC power adapter
8-cell, 86 Wh Li-ion
Bang & Olufsen, dual speakers, HP Audio Boost 2.0, DTS Headphone:X™ support
HP 3D DriveGuard; HP Audio Switch; HP Documentation; HP ePrint; HP e-Service; HP JumpStart; HP Recovery Manager; HP Support Assistant; OMEN Command Center; HP Connection Optimizer
McAfee LiveSafe™ 30-day free trial offer
Pre-installed software
iQiyi
