HP ENVY x360 - 13-ag0001au Product Specifications
4KT87PA
AMD Ryzen™ 3 2300U (2 GHz base frequency, up to 3.4 GHz burst frequency, 6 MB cache, 4 cores)
8 GB DDR4-2400 SDRAM (onboard)
Video graphics
AMD Radeon™ Vega 3 Graphics
256 GB PCIe® NVMe™ M.2 SSD
13.3" diagonal FHD IPS BrightView WLED-backlit micro-edge multitouch-enabled edge-to-edge glass (1920 x 1080)
Keyboard
Full-size island-style backlit keyboard
Pointing device
802.11ac (2x2) Wi-Fi® and Bluetooth® 4.2 combo
1 microSD media card reader
1 USB 3.1 Type-C™ Gen 2 (Data Transfer up to 5 Gb/s, Power Delivery, DisplayPort™ 1.4, HDMI 2.0, HP Sleep and Charge); 2 USB 3.1 Gen 1 (1 HP Sleep and Charge); 1 headphone/microphone combo
30.67 x 21.46 x 1.49 cm
1.3 kg
45 W AC power adapter
4-cell, 53.2 Wh Li-ion
HP Wide Vision HD IR Camera with integrated dual array digital microphone
Bang & Olufsen, quad speakers, HP Audio Boost
HP Audio Switch; HP Documentation; HP ePrint; HP e-Service; HP JumpStart; HP Recovery Manager; HP Support Assistant; HP Connection Optimizer; HP Command Center
Pre-installed software
iQiyi
