    Apache Log4j Update
HP Pavilion x360 - 11-ad101tu Product Specifications
4HG24PA
Intel® Pentium® Silver N5000 (1.1 GHz base frequency, up to 2.7 GHz burst frequency, 4 MB cache, 4 cores)
Video graphics
Intel® UHD Graphics 605
500 GB 5400 rpm SATA
11.6" diagonal HD IPS WLED-backlit multitouch-enabled edge-to-edge glass (1366 x 768)
Keyboard
Full-size island-style keyboard
Pointing device
Intel® 802.11a/b/g/n/ac (1x1) Wi-Fi® and Bluetooth® 4.2 Combo
1 HDMI 1.4; 1 headphone/microphone combo; 3 USB 3.1 Gen 1 (Data transfer only)
29.49 x 20.14 x 1.93 cm
Starting at 1.39 kg
45 W AC power adapter
2-cell, 37.2 Wh Li-ion prismatic
HP TrueVision HD Camera with integrated dual array digital microphone
Dual speakers, HP Audio Boost
HP 3D DriveGuard; HP Audio Switch; HP CoolSense; HP Documentation; HP ePrint; HP JumpStart; HP Recovery Manager; HP Support Assistant; HP System Event Utility
